주요 콘텐츠로 건너뛰기
How to replace a broken back cover on a Sony Xperia Z3
필요한 것
  1. How to replace a broken back cover on a Sony Xperia Z3, The Phone.: 1 단계, 이미지 1/1
    • The cover we are going to replace.
  2. How to replace a broken back cover on a Sony Xperia Z3, Heating.: 2 단계, 이미지 1/2 How to replace a broken back cover on a Sony Xperia Z3, Heating.: 2 단계, 이미지 2/2
    • Start by using a blow-dryer on the hottest setting. Heat the entire backside of the phone, and focus on the edges for a minute or two.
  3. How to replace a broken back cover on a Sony Xperia Z3, Loosening the cover.: 3 단계, 이미지 1/3 How to replace a broken back cover on a Sony Xperia Z3, Loosening the cover.: 3 단계, 이미지 2/3 How to replace a broken back cover on a Sony Xperia Z3, Loosening the cover.: 3 단계, 이미지 3/3
    • Use a suction-cup to pull up the back-cover about 1mm. Insert a pick and use a second one to make the opening larger.
  4. How to replace a broken back cover on a Sony Xperia Z3, Removing the cover.: 4 단계, 이미지 1/3 How to replace a broken back cover on a Sony Xperia Z3, Removing the cover.: 4 단계, 이미지 2/3 How to replace a broken back cover on a Sony Xperia Z3, Removing the cover.: 4 단계, 이미지 3/3
    • Use the picks to get the cover off as far as possible. After this, wear gloves and try to pull off the glass. It will break in this step, so be careful for any pieces of sharp glass!
  5. How to replace a broken back cover on a Sony Xperia Z3, Removing glass.: 5 단계, 이미지 1/2 How to replace a broken back cover on a Sony Xperia Z3, Removing glass.: 5 단계, 이미지 2/2
    • Continue removing the looser pieces. Use plastic tools, so you don't damage the electronics inside.
  6. How to replace a broken back cover on a Sony Xperia Z3, Removing the main piece: 6 단계, 이미지 1/3 How to replace a broken back cover on a Sony Xperia Z3, Removing the main piece: 6 단계, 이미지 2/3 How to replace a broken back cover on a Sony Xperia Z3, Removing the main piece: 6 단계, 이미지 3/3
    • Use the black tabs to pull the white double-sided tape. Remember not to pull these up, but stretch them to the sides. Pull carefully to avoid snapping.
  7. How to replace a broken back cover on a Sony Xperia Z3, More glass.: 7 단계, 이미지 1/3 How to replace a broken back cover on a Sony Xperia Z3, More glass.: 7 단계, 이미지 2/3 How to replace a broken back cover on a Sony Xperia Z3, More glass.: 7 단계, 이미지 3/3
    • You can now take off the glass that was attached to the battery.
    • Carefully remove all the glass and tape that's left.
    • Clean out all the glass with a small soft brush. I used the tip of an soft toothbrush.
  8. How to replace a broken back cover on a Sony Xperia Z3, NFC sticker.: 8 단계, 이미지 1/3 How to replace a broken back cover on a Sony Xperia Z3, NFC sticker.: 8 단계, 이미지 2/3 How to replace a broken back cover on a Sony Xperia Z3, NFC sticker.: 8 단계, 이미지 3/3
    • Be sure to clean all the glass! Use tape to carefully pick up the small pieces.
    • We still need to remove the NFC sticker to place in the new cover.
    • Carefully peel it off the old cover.
    On my Z3 it was not possible to just peel it off. I had to heat it repeatedly with a blow dryer and then gently "saw" with sharp knife between the sticker and the back piece. Wery good description though. The You Tube clip i found didn't mention the NFC antenna at all.
    andtom99 - 답글
  9. How to replace a broken back cover on a Sony Xperia Z3, Placing the NFC sticker.: 9 단계, 이미지 1/3 How to replace a broken back cover on a Sony Xperia Z3, Placing the NFC sticker.: 9 단계, 이미지 2/3 How to replace a broken back cover on a Sony Xperia Z3, Placing the NFC sticker.: 9 단계, 이미지 3/3
    • Place the NFC sticker in the free space in the tape on the inside of the new cover.
    • Press it down.
    • The contact sensitive area on the sticker will line up with the connectors on the motherboard.
  10. How to replace a broken back cover on a Sony Xperia Z3, The new cover.: 10 단계, 이미지 1/3 How to replace a broken back cover on a Sony Xperia Z3, The new cover.: 10 단계, 이미지 2/3 How to replace a broken back cover on a Sony Xperia Z3, The new cover.: 10 단계, 이미지 3/3
    • This is our new cover. Why not a new color? Not too expensive on eBay. This is an aftermarket version.
    • Peel off the protective plastic.
  11. How to replace a broken back cover on a Sony Xperia Z3, Placing the new cover.: 11 단계, 이미지 1/2 How to replace a broken back cover on a Sony Xperia Z3, Placing the new cover.: 11 단계, 이미지 2/2
    • Line the cover up with one of the corners and align it along the long edge.
    • Before you drop it in, you can make small adjustment to line it up with the opposite corner.
    • Gently press it down along all edges and about two thirds down, where the cover sticks to the battery.
  12. How to replace a broken back cover on a Sony Xperia Z3, Finishing touches.: 12 단계, 이미지 1/2 How to replace a broken back cover on a Sony Xperia Z3, Finishing touches.: 12 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    구매
    • Wipe all smudges off the back with a microfiber cloth.
    • Give it one last press along the edges while wiping.
    • And we're done. A nice new gold back cover for an Xperia Z3.
    • If you want you can protect the glass with a tempered screen-protector. Keep in mind that this may influence your case choice.
결론
The phone is normally waterproof, and should still be, after this repair. However, I have not tested it, so I can not give a conclusive answer on how water-proof the device stays after repair.
다른 48명이 해당 안내서를 완성하였습니다.
larsjj
회원 가입일: 09/11/15
1,549 평판
안내서 1개 작성함
댓글 11개
My european Sony Xperia Z3 had much more glue attached to the battery, making it much harder to remove all of the glas.
Max A - 답글
Worked anyhow :-) Looks awesome again!
Thanks for the guide!
Max A -
My new back just won't stay stuck down. Can ib use super glue on it? I think half the battle is the phone heating up and loosening the glue.
Ben Clayton - 답글
I'd be careful using superglue. Some sticky kit might be better. Maybe heating up the new one and holding it down with clamps or a book should make it stick better too.
larsjj -
Hi, I replace The back cover this morning and everything work well but when I attached the new back cover power button stopped working :(.. Do you have any suggestion what I should do? If I plug it into the USB it started charging and screen work but I cannot get it to power on..
Nezha - 답글
I just replaced the back, and it looks great. However, I've turned it back on and it is without service. Everything else is working perfectly.
jennifarrow - 답글
is it still waterproof after this?
tanadibatman - 답글
I saw on another thread about this problem, that nobody will assure you of this when DIYing the repair... unfortunatelly...
t.satrova -
That's why I put this at the end:
"The phone is normally waterproof, and should still be, after this repair. However, I have not tested it, so I can not give a conclusive answer on how water-proof the device stays after repair."
larsjj -
Yeah - important step - scrape off all the excess glue on the metal chassis before trying to attach a new cover, or you'll have a loose back. Had to buy another back and try again.
Thomas Morgan - 답글
Does that lose him the water warranty?
bassem elfrgany - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 19
전체 시간: 44,877
