주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to replace a broken towel hook on drywall
필요한 것
    1. How to replace a broken towel hook on drywall, Towel Hook: 1 단계, 이미지 2개 중 1개 How to replace a broken towel hook on drywall, Towel Hook: 1 단계, 이미지 2개 중 2개
      • Using your Phillips screwdriver, remove both screws that are keeping your current (broken) drywall hook in place.
      • Make sure you remove both screws evenly, to avoid bending and damaging the screws and the drywall around it.
      댓글 쓰기
    2. How to replace a broken towel hook on drywall: 2 단계, 이미지 1개 중 1개
      • After removing both screws, remove the plastic anchor screws from the drywall.
      • It will leave a big hole, but we will fix that!
      댓글 쓰기
    3. How to replace a broken towel hook on drywall: 3 단계, 이미지 3개 중 1개 How to replace a broken towel hook on drywall: 3 단계, 이미지 3개 중 2개 How to replace a broken towel hook on drywall: 3 단계, 이미지 3개 중 3개
      • After removing the anchor screws, take your spatula and press it flush with the wall. Remove debris from the drywall to make the wall flat.
      댓글 쓰기
    4. How to replace a broken towel hook on drywall: 4 단계, 이미지 2개 중 1개 How to replace a broken towel hook on drywall: 4 단계, 이미지 2개 중 2개
      • Take some patching and with your spatula, apply it on and around the holes in order to fill it up to the surface of the wall.
      댓글 쓰기
    5. How to replace a broken towel hook on drywall: 5 단계, 이미지 2개 중 1개 How to replace a broken towel hook on drywall: 5 단계, 이미지 2개 중 2개
      • Select a new location for your new towel hook and, with one of the screws, mark the spot where you'll drill the holes.
      • Use your screwdriver to tap the two new locations, to make it easier to screw the anchors onto the wall.
      댓글 쓰기
    6. How to replace a broken towel hook on drywall: 6 단계, 이미지 2개 중 1개 How to replace a broken towel hook on drywall: 6 단계, 이미지 2개 중 2개
      • Take your new anchor screws and start drilling on your marked holes.
      • Keep screwing them into the drywall until they're flush with the wall.
      • Don't drill too far, or else it will damage the drywall and the towel hook will be uneven!
      댓글 쓰기
    7. How to replace a broken towel hook on drywall: 7 단계, 이미지 3개 중 1개 How to replace a broken towel hook on drywall: 7 단계, 이미지 3개 중 2개 How to replace a broken towel hook on drywall: 7 단계, 이미지 3개 중 3개
      • Line up your new towel hook with the holes where the anchors are located.
      • Take your screws and start screwing them in manually so they stay in place.
      댓글 쓰기
    8. How to replace a broken towel hook on drywall: 8 단계, 이미지 1개 중 1개
      • With your screwdriver, continue screwing the screws in until they're flush with the towel hook.
      댓글 쓰기
    9. How to replace a broken towel hook on drywall: 9 단계, 이미지 1개 중 1개
      • Voila! Your new towel hook is installed!
      • But how about the hole we patched earlier?
      댓글 쓰기
    10. How to replace a broken towel hook on drywall: 10 단계, 이미지 2개 중 1개 How to replace a broken towel hook on drywall: 10 단계, 이미지 2개 중 2개
      • Press the sandpaper against the wall and scrub on and around the hole, to level it with the wall.
      • After doing that for a few seconds, your patch should be leveled and your problem, solved!
      댓글 쓰기
결론
This guide shows both removing the old, broken towel hook and installing the new towel hook! Hope it helped!
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Pietro Coso
회원 가입일: 03/21/20
211 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 25
지난 30일: 117
전체 시간: 2,974
