필요한 것
It is advisable to work with two people, one holding the outer handle on the outside and the other unloading the screw on the other side.
Remove the two screws.
Use pry bar carefully pry around, you can remove both sides of the door handle.
Reversing the steps to know hot to install the know. It's easier than your thought , isn't it?
다른 5명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
