주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to replace the main PCB
필요한 것
  1. How to replace the main PCB, Remove the screws: 1 단계, 이미지 1개 중 1개
    • Unscrew the four screws of the metal plate underneath the Warthog.
  2. How to replace the main PCB, Remove internal screws and cables: 2 단계, 이미지 2개 중 1개 How to replace the main PCB, Remove internal screws and cables: 2 단계, 이미지 2개 중 2개
    • Carefully remove the four screws displayed on the picture.
    • Disconnect the two cables displayed on the picture by making sure to not damage them. A pair of flat pliers might be recommended.
  3. How to replace the main PCB, Unsolder the PCB: 3 단계, 이미지 1개 중 1개
    • Using a soldering iron, remove the previous PCB and replace it with the new one.
    • Once that is done, reassemble the product.
  4. How to replace the main PCB, Update the firmware : open the updater: 4 단계, 이미지 2개 중 1개 How to replace the main PCB, Update the firmware : open the updater: 4 단계, 이미지 2개 중 2개
    • You will then need to update the firmware of the new PCB. To do that, connect the Magnetic Base (with a joystick on it) to your computer.
    • (First picture) If you have not already, download and install the driver of the product available on Thrustmaster support : https://support.thrustmaster.com/en/prod...
    • (Second picture) Open the "Firmware Updater". To do that, write "Firmware Updater" in the Windows search bar, the open the software.
  5. How to replace the main PCB, Update the firmware: 5 단계, 이미지 3개 중 1개 How to replace the main PCB, Update the firmware: 5 단계, 이미지 3개 중 2개 How to replace the main PCB, Update the firmware: 5 단계, 이미지 3개 중 3개
    • (First picture) Your device appears in the firmware updater. Apply the update by clicking on "OK".
    • (Second picture) The update is in progress.
    • (Third picture) The update is done ! You can close the firmware updater by clicking on the arrow at the top right corner.
  6. How to replace the main PCB, Calibration - Getting the software: 6 단계, 이미지 3개 중 1개 How to replace the main PCB, Calibration - Getting the software: 6 단계, 이미지 3개 중 2개 How to replace the main PCB, Calibration - Getting the software: 6 단계, 이미지 3개 중 3개
    • (Picture 1) Finally, you need to recalibrate the device. Thrustmaster has made this tool available here: https://nextcloud.guillemot.fr/index.php...
    • (Picture 2) Extract the archived file on your computer.
    • (Picture 3) Launch the calibration software.
  7. How to replace the main PCB, Calibration: 7 단계, 이미지 1개 중 1개
    • The calibration software will detail all the steps to follow. Make sure your Warthog Stick is connected to your computer, with a compatible joystick mounted on it.
    • Once you have fully followed all the steps of the calibration tool, you are done !
결론
작성자
1다른 기여자 명과 함께
SarahK
회원 가입일: 08/16/24
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 39
전체 시간: 451
