소개
Use this guide to swap a leaking or cracked salt container and restore your dishwasher’s water-softening system. A damaged container can trigger Aquastop alarms, cause leaks onto the floor, or result in cloudy dishes due to mineral buildup.
You'll learn how to safely diagnose the issue, remove the old container, document wiring, and install a replacement without damaging connected components.
For help with common salt-related issues, browse our dishwasher Q&A forum for community-solved cases.
필요한 것
1 단계 Diagnose a faulty salt container
Watch for continuous pumping with the door open or an active Aquastop alarm.
Look for unexplained water under basic models that lack Aquastop.
Leaks usually start at the welded seam on the bottom of the salt container.
2 단계 Disconnect power and protect the area
Collect a screwdriver, adjustable pliers, towels, and a phone or camera.
3 단계 Remove the decorative front cover
Undo the left‑hand screw securing the cover to the door frame.
Remove the matching screws on both sides.
Tilt and lift the cover away to expose the salt filler neck.
4 단계 Document all wiring
Photograph every wire on the inlet valves and microswitch with a smartphone.
6 단계 Release the salt container
Remove the external screw that locks the container to the chassis.
Unscrew the inner retaining ring surrounding the filler neck; use pliers if tight.
7 단계 Disconnect hoses and extract the container
Detach the rubber hoses from the container base while holding it steady.
Remove the complete container assembly from the cabinet.
8 단계 Prepare and install the new container
Reconnect each hose to the matching port on the new container.
Seat the container, hand‑tighten the retaining ring, then snug it with pliers.
Refit and tighten the external mounting screw.
9 단계 Reassemble and test
Reinstall the side panel, reconnect wires using your photos, and fit the front cover.
Fill the container with dishwasher salt and add about 500 ml of water to prime it.
Run a short rinse programme to flush air and activate the softening circuit.
With the new salt container primed and the rinse cycle completed, the dishwasher’s softening system is back in service. Keep the reservoir filled with proper dishwasher salt and repeat short rinse cycles after every refill to maintain clear, spot‑free results.
