소개
Replacing a worn or cracked screen protector keeps your phone’s original glass safe from scratches and impacts. Follow this guide to clean the device, prepare a dust-free surface, and apply a new protective glass for a clear, bubble-free finish that lasts.
필요한 것
1 단계 Remove and wash the case
Slide the phone out of its protective case.
Clean the case with warm water and a small amount of mild soap, then allow it to dry completely.
2 단계 Clean the earpiece speaker grill
Rub a soft pencil eraser gently across the earpiece grill to pull out packed dirt.
3 단계 Wipe the phone exterior with alcohol
Wipe the screen and body with a microfiber cloth lightly moistened with cleaning alcohol.
Work around the edges until all visible smudges disappear.
4 단계 Clean tight ports and buttons
Dip a cotton swab in alcohol, press off excess, then lightly sweep around buttons, speakers, and the charging port.
5 단계 Prepare a dust-free workspace
Turn off fans and avoid activities that stir up lint or dust in the room.
6 단계 Remove the old screen protector
Hook a fingernail under one corner of the old protector and peel it away from the display.
7 단계 Clean the bare screen with the wet wipe
Use the moist wipe supplied in the protector kit to thoroughly clean the display, especially around the bezels.
8 단계 Dry and polish the screen
Buff the glass with the dry wipe from the kit until all moisture is gone.
Follow with a high quality microfiber cloth to polish the surface without leaving lint.
Tilt the phone and inspect; the screen must be completely free of dust and fingerprints.
9 단계 Lift remaining dust with the removal sticker
Tap the supplied dust-removal sticker across the display to pick up any last specks.
10 단계 Expose the adhesive side of the new protector
Peel the film from the side marked for the screen to reveal the adhesive surface.
11 단계 Align and lower the protector
Position the glass over the display so the cut-outs align with the camera and sensors.
Lower the protector slowly onto the screen.
12 단계 Bond the glass and remove bubbles
Press the center of the protector so the adhesive spreads to the edges.
Wrap a microfiber cloth around a finger and push any air pockets toward the sides until they disappear.
13 단계 Reinstall the case and finish up
Give the glass a final wipe, then snap the phone back into its clean, dry case.
Your phone now sports a spotless, perfectly aligned screen protector, ready to guard the display against daily wear and accidental drops. Keep the dust-removal sticker handy for quick touch-ups, and enjoy a crystal-clear view.
다른 한 분이 해당 안내서를 완성하였습니다.
