주요 콘텐츠로 건너뛰기
How to reset Cisco 7940 / 7960 IP phone to factory defaults
필요한 것
    • In order to perform a factory reset of a phone if the password is set, complete these steps: 1. Unplug the power cable from the phone, and then plug in the cable again. The phone begins its power up cycle.
    • 2. Immediately press and hold # and while the Headset, Mute, and Speaker buttons begin to flash in sequence, release #. The Headset, Mute, and Speaker buttons flash in sequence in order to indicate that the phone waits for you to enter the key sequence for the reset.
    • 3. Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash. If you repeat a key within the sequence, for example, if you press 1223456789*0#, the sequence is still accepted and the phone resets.
    • If you do not complete this key sequence or do not press any keys, after 60 seconds, the Headset, Mute, and Speaker buttons no longer flash, and the phone continues with its normal startup process. The phone does not reset. If you enter an invalid key sequence, the buttons no longer flash, and the phone continues with its normal startup process.
    • If you enter this key sequence correctly, the phone displays this prompt: Keep network cfg? 1 = yes 2 = no
    • In order to reset the network configuration settings when the phone resets, press 2.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
Goulithum
회원 가입일: 01/09/15
1,534 평판
안내서 2개 작성하였습니다
Sage Electronics Sage Electronics 회원
Business
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
Just follow the easy steps, and it is reset within a minute or two.
Anders Busk - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 45
전체 시간: 27,120
