주요 콘텐츠로 건너뛰기
How to reset the PIN of a Flipper Zero
  1. How to reset the PIN of a Flipper Zero, Reset your PIN: 1 단계, 이미지 1개 중 1개
    • Hold the Up- and Back-buttons for 30 seconds.
  2. How to reset the PIN of a Flipper Zero, Confirm the Reset: 2 단계, 이미지 1개 중 1개
    • Confirm the reset procedure by holding the Right-button.
결론
Try to remember your PIN next time!
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sebastian
회원 가입일: 08/19/18
31,160 평판
안내서 71개를 작성함
4가이드 댓글
Every time I attempt this, it goes black 20 seconds in the 30 seconds and resets the locked timer.
vmmmp - 답글
You have to wait until the timer ends and it asks for the passcode again. Only THEN can you perform the steps. I just successfully did so after experiencing the same issue as you.
Massimo Cracchiolo - 답글
If i do the same steps my flipper says: Flipper crashed and was rebooted HardFault. What can i do? is there maybe another way ?
Anke Seeland (Ankmaus) - 답글
i got the pin for the flipper : Left Up Right Down = press Insert
Cezar Khaloul - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 30
지난 30일: 163
전체 시간: 14,044
