소개
Mac Laptop not booting up properly? Strange things happening to your beloved Mac? Resetting your SMC, PRAM, and NVRAM might help!
If you have a MacBook Pro 2018 Model with a T2 Chip head over to this guide as the steps are different for that model.
Choose Apple menu > Shut Down.
After your Mac shuts down, press Shift-Control-Option on the left side of the built-in keyboard, then press the power button at the same time. Hold these keys and the power button for 10 seconds. If you have a MacBook Pro with Touch ID, the Touch ID button is also the power button.
Release all keys. Press the power button again to turn on your Mac.
Power down your Mac.
Remove the battery.
If you are unsure how to remove your Mac's battery, head on over to this linkand select your Mac's make and model.
Once you have removed the battery, press and hold the power button for 5 seconds.
Release the power button. Reinstall the battery.
Press the power button again as you would to turn on the Mac.
Shut down the computer
Press the Power button
Before the grey color screen is shown, press and hold Command + Option + P + R keys simultaneously.
Hold down these keys until the MacBook restarts and then you will hear the startup sound.
Release the keys.
If these reset did not help you with your Mac, head on over to the Answers Forum (if you have not already been there) and ask our friendly community for the next steps.
다른 28명이 해당 안내서를 완성하였습니다.
댓글 2개
Got a 2012 Macbook Pro. Was running GIMP with a couple Browsers open and Word. Gimp crashed twice and I had to restart it. I saved a GIMP file to a png. Placing one png over another, it all froze: Cursor and all not moving. Pressed Cntrl/alt/shift, etc and it closed the the first application open, in layered fashion, but until I got to the last finder window, it kept opening. Shut down completely. Start up took about 2 minutes (usually 37 seconds. Has 2TB SSD and 10GB memory). Was super fast, until today).
When I click on any file or program, it hesitates for a second, then opens as if it’s on a delay, with an odd trace of lighting or movement tracks. Tried the finder “search” and it isnt’ recognizing anything, like it’s not accessing directories, etc. Had to open Applications, to get DiskUtility and run it. Nothing changed. There is a thin grey line that appears to run horizontally through the middle of the “search box”. What’s up???
