소개
The tutorial will show you how to fix no SIM card hardware problem. Follow the guide to restore your iPhone 6 to the proper order.
필요한 것
This Tutorial will show you how to fix the No SIM Card hardware problem. Follow the guide to restore your iPhone 6 to get SIM Cards to work.
다른 11명이 해당 안내서를 완성하였습니다.
댓글 3개
i actually found a solution for this error you can follow Solution No. 1 provided with this website works for me
https://www.errorsolutions.tech/error/ip...
very informative and has a picture on it easy.
you can also try this, perform Network reset also sort out this issue.
Where do I get new IC?
The best way is to get it from the other motherboard.
iPhone 6 sim card provides
pankaj sinsinwar - 답글
