주요 콘텐츠로 건너뛰기
How to restore a shrunken sweater
필요한 것
  1. How to restore a shrunken sweater, How to restore a shrunken sweater: 1 단계, 이미지 1/1
    • Add 2/3 full of water into the washbasin.
    • Add 20 ml of Baby Shampoo into the washbasin.
    • The volume of water needed depends on the size of the sweater. The larger the sweater, the more water needed.
  2. How to restore a shrunken sweater: 2 단계, 이미지 1/1
    • Soak the sweater into the washbasin with soapy water for 15 mins.
  3. How to restore a shrunken sweater: 3 단계, 이미지 1/3 How to restore a shrunken sweater: 3 단계, 이미지 2/3 How to restore a shrunken sweater: 3 단계, 이미지 3/3
    • Take out the sweater from the washbasin with soapy water.
    • Remove the sweater to the bucket filled with fresh warm water.
    • Rinse the sweater thoroughly.
  4. How to restore a shrunken sweater: 4 단계, 이미지 1/1
    • Take out the sweater from the bucket.
    • Wring the clothes gently to get excessive water out.
  5. How to restore a shrunken sweater: 5 단계, 이미지 1/1
    • Place the sweater flat in the center of the bath towel.
  6. How to restore a shrunken sweater: 6 단계, 이미지 1/3 How to restore a shrunken sweater: 6 단계, 이미지 2/3 How to restore a shrunken sweater: 6 단계, 이미지 3/3
    • Roll while wringing the towel together with the sweater in order to dry the sweater.
    • Redo the process for a couple times until the sweater is dry to the touch.
    • Unfold the towel and take out the sweater
    • Spread out the sweater flat and let it dry.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Zhou Zhou
회원 가입일: 10/26/18
148 평판
안내서 1개 작성함
UC Davis, Team S2-G8, Bender Fall 2018 UC Davis, Team S2-G8, Bender Fall 2018 회원
UCD-BENDER-F18S2G8
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 422
