주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Do you have an acoustic guitar that needs to be restrung? Follow the steps to restring your instrument and make it sound brand new again.
도구
  1. Twist the 6 knobs in appropriate directions to unstring the guitar.
    • Twist the 6 knobs in appropriate directions to unstring the guitar.
    • There are six strings on a guitar. From the thickest string to thinest, or left to right, the stings are named E(low), A, D, G, B, and E(high) strings.
    • In order to unstring the strings, turn the knobs for E(low), A, and D strings in clockwise direction and turn the knobs for G, B, E(high) strings in counter clock wise direction.
  2. Carefully remove the pins from the bridge and remove the old strings. Carefully remove the pins from the bridge and remove the old strings.
    • Carefully remove the pins from the bridge and remove the old strings.
  3. Take the new strings out of of the package. Pin the stings onto the bridge, into the pinholes from left to right in the following order; E(low)-A-D-G-B-E(high). Refer to the cover of guitar strings package to distinguish the strings.
    • Take the new strings out of of the package.
    • Pin the stings onto the bridge, into the pinholes from left to right in the following order; E(low)-A-D-G-B-E(high).
    • Refer to the cover of guitar strings package to distinguish the strings.
  4. Insert the end of each string into the head machine. Leave about 1 to 2 inches of string from the head machine and cut it using a clipper. Repeat the process for all six strings.
    • Insert the end of each string into the head machine.
    • Leave about 1 to 2 inches of string from the head machine and cut it using a clipper.
    • Repeat the process for all six strings.
  5. Guide the string through the pin hole, so that about 1/3 of an inch of excess string comes out from behind the pin.
    • Guide the string through the pin hole, so that about 1/3 of an inch of excess string comes out from behind the pin.
    • Turn the knobs in a counterclockwise direction for E(low), A, D strings.
    • Turn the knobs in a clockwise direction for G, B, E(high) strings.
  6. Clip the tuner on the head of the guitar and turn it on. Tune each string by plucking the string and checking the letter musical note indicated on the tuner. From left to right, the appropriate musical notes of the strings are, E-A-D-G-B-E
    • Clip the tuner on the head of the guitar and turn it on.
    • Tune each string by plucking the string and checking the letter musical note indicated on the tuner.
    • From left to right, the appropriate musical notes of the strings are, E-A-D-G-B-E
결론
다른 3명이 해당 안내서를 완성하였습니다.
Brian Yoon
회원 가입일: 2015년 02월 23일
210 평판
안내서 1개 작성함
Cal Poly, Team 12-3, Green Winter 2015 Cal Poly, Team 12-3, Green Winter 2015 회원
CPSU-GREEN-W15S12G3
4 회원들
안내서 5개 작성하였습니다
Great to know the restring process for acoustic guitar. I am searching for such type of a blog since I need to replace the old string of my guitar and install new strings. The steps mentioned here are very much clear what to do and anyone can easily understand what he/she has to do. I have gone through all the steps and I hope that with the help of these steps I can also able to replace with my newly purchased(https://faberusa.com/product-category/tu... tuner buttons.
netahnpaul86 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 67
전체 시간: 3,855
