주요 콘텐츠로 건너뛰기
How to rewire a Nostalgia Electrics PCM805
필요한 것
  1. How to rewire a Nostalgia Electrics PCM805, Nostalgia Electrics PCM805 Wiring Teardown: 1 단계, 이미지 2개 중 1개 How to rewire a Nostalgia Electrics PCM805, Nostalgia Electrics PCM805 Wiring Teardown: 1 단계, 이미지 2개 중 2개
    • Locate the tie strap holding the wires and cut with a pair of scissors.
    • Use care not to snip the wires.
  2. How to rewire a Nostalgia Electrics PCM805: 2 단계, 이미지 3개 중 1개 How to rewire a Nostalgia Electrics PCM805: 2 단계, 이미지 3개 중 2개 How to rewire a Nostalgia Electrics PCM805: 2 단계, 이미지 3개 중 3개
    • Make note of the wiring arrangement of each bundle before this step.
    • Using wire cutters, cut each wire as close to the wire connector as possible.
    • Cut the wires in both bundles.
    • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
  3. How to rewire a Nostalgia Electrics PCM805, How to rewire a Nostalgia Electrics PCM805: 3 단계, 이미지 2개 중 1개 How to rewire a Nostalgia Electrics PCM805, How to rewire a Nostalgia Electrics PCM805: 3 단계, 이미지 2개 중 2개
    • Using the wire stripper, remove 1/2 inch of the wire insulation at the end of each wire to expose the bare wire for re-connection.
  4. How to rewire a Nostalgia Electrics PCM805: 4 단계, 이미지 3개 중 1개 How to rewire a Nostalgia Electrics PCM805: 4 단계, 이미지 3개 중 2개 How to rewire a Nostalgia Electrics PCM805: 4 단계, 이미지 3개 중 3개
    • Twist the exposed ends of the wires so that they stay together.
    • Push the wire cap onto the exposed ends while holding the wires and twist in a clock-wise direction until it is tight.
    • Repeat this process for both bundles of wires.
    • Do not attempt to power on the device without the wire caps on or mix wires between the bundles.
결승점
작성자
5다른 기여자 명과 함께
Carlton
회원 가입일: 01/13/15
672 평판
안내서 5개를 작성함
USF Tampa, Team 3-5, Hickman Winter 2015 USF Tampa, Team 3-5, Hickman Winter 2015 회원
USFT-HICKMAN-W15S3G5
5 회원들
안내서 8개를 작성함
1가이드 댓글
DO NOT TRY THIS..it broke my machine TO NOT TRY THIS
Izzy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 856
