주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to save fresh corn
  1. How to save fresh corn, How to save fresh corn: 1 단계, 이미지 1개 중 1개
    • Six ears of fresh corn
  2. How to save fresh corn: 2 단계, 이미지 3개 중 1개 How to save fresh corn: 2 단계, 이미지 3개 중 2개 How to save fresh corn: 2 단계, 이미지 3개 중 3개
    • Use a very sharp or serrated edge knife and cut off the shank of the ear. Then cut off the silts end. FYI there is one silt for each kernel of corn. Now peal off most of the husks but leave the corn covered with at least one layer.
  3. How to save fresh corn: 3 단계, 이미지 3개 중 1개 How to save fresh corn: 3 단계, 이미지 3개 중 2개 How to save fresh corn: 3 단계, 이미지 3개 중 3개
    • Now your ears are ready for cooking.
    • I do them three at a time in the microwave. Allow three minutes for each ear. To insure even cooking, turn and rotate the ears every three minutes.
  4. How to save fresh corn: 4 단계, 이미지 3개 중 1개 How to save fresh corn: 4 단계, 이미지 3개 중 2개 How to save fresh corn: 4 단계, 이미지 3개 중 3개
    • The corn can now be husked and eaten straight off the cob. If you are doing more ears than you can eat right now, the corn can be taken off the cob and frozen. To remove the husks and the majority of the slits, use a kitchen towel to grasp the corn and cut off bottom end. The squeeze the ear right out of the husk.
  5. How to save fresh corn: 5 단계, 이미지 3개 중 1개 How to save fresh corn: 5 단계, 이미지 3개 중 2개 How to save fresh corn: 5 단계, 이미지 3개 중 3개
    • The corn will slip right out of the husks. It will also be almost free of those pesky silts.
  6. How to save fresh corn: 6 단계, 이미지 3개 중 1개 How to save fresh corn: 6 단계, 이미지 3개 중 2개 How to save fresh corn: 6 단계, 이미지 3개 중 3개
    • Time to take the kernels off the cob. Use a very sharp paring knife. Hold the hot corn with your kitchen towel and start about the middle of the ear and cut the kernels off into a bowl.
  7. How to save fresh corn: 7 단계, 이미지 2개 중 1개 How to save fresh corn: 7 단계, 이미지 2개 중 2개
    • Here are three ears cut off into the bowl.
    • Here are all six ears in the bowl.
  8. How to save fresh corn: 8 단계, 이미지 3개 중 1개 How to save fresh corn: 8 단계, 이미지 3개 중 2개 How to save fresh corn: 8 단계, 이미지 3개 중 3개
    • Final prep is to add one pat of butter per ear, then add fresh ground salt and pepper to taste. To melt the butter put the bowl back in the microwave for a couple of minutes, then stir well.
    • Use a good quality freezer bags. Fill your bags, About 6-7 tablespoons for each ear of corn. I freeze only one ear per bag as that's all I will eat at a time.
    • Here are my completed bags ready for the freezer.
    • Frozen corn will last with good quality about 12 months.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
mayer
회원 가입일: 01/04/10
689,814 평판
안내서 11개를 작성함
Greybeards Greybeards 회원
Community
8 회원들
안내서 37개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 40
전체 시간: 718
