주요 콘텐츠로 건너뛰기
How to set up a Home Theater System
필요한 것
  1. How to set up a Home Theater System, Part one the Sony Home Theater System: 1 단계, 이미지 2개 중 1개 How to set up a Home Theater System, Part one the Sony Home Theater System: 1 단계, 이미지 2개 중 2개
    • This is the wireless receiver for the Sony Home Theater System, picture two shows the connections and the wireless card.
  2. How to set up a Home Theater System, Back of the Sony Wireless transceiver: 2 단계, 이미지 1개 중 1개
    • As you can see the blue and gray plugs are inserted in the blue and gray sockets. The small black dongle is the wireless card.
  3. How to set up a Home Theater System, Back of the Sony Home Theater System: 3 단계, 이미지 2개 중 1개 How to set up a Home Theater System, Back of the Sony Home Theater System: 3 단계, 이미지 2개 중 2개
    • As you can see the red and white connectors need to match, but in my case that was the only color connectors I have, The blue one (red) goes to the right front speaker, the gray one (white) goes to the left front speaker, the purple one goes to the sub woofer, and the green one goes to the center speaker.
  4. How to set up a Home Theater System, Speakers used: 4 단계, 이미지 3개 중 1개 How to set up a Home Theater System, Speakers used: 4 단계, 이미지 3개 중 2개 How to set up a Home Theater System, Speakers used: 4 단계, 이미지 3개 중 3개
    • The first speaker is the right front speaker. (There are two of them, one in the left corner of the room, and one in the right corner of the room). The two small speakers in the 2nd and third pictures are the surround sound speakers.
    • This basically shows you what you can get in 20 seconds.
결론
Setup is easy, in the next tutorial I will show you how to set up and record records and tapes.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
rcamp48
회원 가입일: 05/09/19
187 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 20
전체 시간: 557
