주요 콘텐츠로 건너뛰기
How to stop bicycle brakes from squeaking
필요한 것
  1. How to stop bicycle brakes from squeaking, How to stop bicycle brakes from squeaking: 1 단계, 이미지 1개 중 1개
    • Loosen the brake pads from the calipers using a 10mm wrench.
    • You will need to repeat this step for the second brake pad located on the other side of the wheel.
  2. How to stop bicycle brakes from squeaking: 2 단계, 이미지 1개 중 1개
    • Remove the brake pads from the calipers.
  3. How to stop bicycle brakes from squeaking: 3 단계, 이미지 1개 중 1개
    • Clean the surface of the brake pad with a cloth or water if necessary.
    • The surface of the rims where the brake pads make contact may also need to be cleaned.
  4. How to stop bicycle brakes from squeaking: 4 단계, 이미지 1개 중 1개
    • Reattach the brake pads to the calipers and tighten them with the 10mm wrench so that the leading edge of the brake sits closer to the rim than the rear edge.
  5. How to stop bicycle brakes from squeaking: 5 단계, 이미지 1개 중 1개
    • Check the brake cable and make sure that it is still connected and secured to the brake calipers.
  6. How to stop bicycle brakes from squeaking: 6 단계, 이미지 1개 중 1개
    • Test the brake to ensure that it functions properly before riding the bike.
결론
작성자
4다른 기여자 명과 함께
Kevin Colon
회원 가입일: 02/08/18
160 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 16
전체 시간: 1,984
