주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to test an iPhone's Battery
  1. How to test an iPhone's Battery, Get coconutBattery: 1 단계, 이미지 1개 중 1개
    • Head on over to the coconutBattery website and grab a copy of coconutBattery.
    • I used coconutBattery 3.7 for this tutorial, and if the UI ever changes in the future I will promptly update this guide as needed.
    • Hit that download button. It should be downloading into wherever you set your downloads to download to.
    • coconutBattery Website
  2. How to test an iPhone's Battery, Opening coconutBattery: 2 단계, 이미지 1개 중 1개
    • Lucky us! coconutBattery is already ready to run after being downloaded.
    • Double click on the coconutBattery application.
    • The location of where you have saved the coconutBattery application may vary. For me, I saved it to my Downloads folder.
  3. How to test an iPhone's Battery: 3 단계, 이미지 1개 중 1개
    • Now, get the charger (lightning pin cable) for your iDevice and plug the USB-A port into your Mac and the Lightning Pin into your iDevice.
    • Click the iOS device icon and you should be directed to the iOS device battery page.
  4. How to test an iPhone's Battery, Information: 4 단계, 이미지 1개 중 1개
    • All done! Now you can see...
    • Device information...
    • Advanced device information...
    • Battery information
    • Charger information
    • If you have been sent here by a user on the Answers Forum or are going to ask a question about your iDevice's battery on the answers forum, take a screenshot of this entire window and upload it with your question.
    • If you are unsure how to upload your screenshot to your existing question, you can use guide Adding Images to an Existing Question.
    • I was using my iPad for this guide because I left my iPhone at home. The steps should be no different with using an iPhone.
결론
You're done!
다른 23명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
[deleted]
회원 가입일: 08/28/18
27,871 평판
안내서 21개를 작성함
2가이드 댓글
Hello guys,
Is this app only for MacOs?
cheers
David Celis - 답글 공유
CoconutBattery is NOT available as an app for iOS
Thomas Scharold - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 52
지난 30일: 235
전체 시간: 8,314
