주요 콘텐츠로 건너뛰기
How to Tighten GEN 2 Wheelchair Wheels
필요한 것
  1. How to Tighten GEN 2 Wheelchair Wheels, How to Tighten GEN 2 Wheelchair Wheels: 1 단계, 이미지 1/1
    • Inspect the chair to see which wheel is loose.
    • Tighten the outer bolt with a 19 mm socket wrench.
  2. How to Tighten GEN 2 Wheelchair Wheels: 2 단계, 이미지 1/1
    • Tighten the nut facing the inside of the chair with a 19 mm wrench.
결론
If wheel does not feel properly secured, keep tightening the wheel in small amounts until the wheel is secure.
Kali Slaughter
회원 가입일: 04/19/13
207 평판
안내서 5개 작성하였습니다
Cal Poly, Team 14-8, Maness Spring 2013 Cal Poly, Team 14-8, Maness Spring 2013 회원
CPSU-MANESS-S13S14G8
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 1,881
