주요 콘텐츠로 건너뛰기
How to turn a iMac Intel into an External Monitor
  1. How to turn a iMac Intel into an External Monitor, Gut the iMac: 1 단계, 이미지 1/1
    • Firstly, I completely gutted the iMac, safely keeping the LCD screen to one side. I also repaired any torn EMI shielding and shielded all holes, with the exception of the power in, vent above this. (I also left the 3x USB ports free to fit a USB hub, but this didn't work great, so ended up being removed).
  2. How to turn a iMac Intel into an External Monitor, Find a LCD display driver board: 2 단계, 이미지 1/1
    • I next found out that my screen was a Samsung LTM201M1-L01 and after scouring eBay with this model number, I managed to find a display driver for this screen from eBay - just search for your screen model number
    • My LCD driver board has VGA, DVI and HDMI in and is powered by a 12V 4A external PSU - the eBay seller also sold PSUs, but I had one kicking about from another LCD screen.
  3. How to turn a iMac Intel into an External Monitor, Test driver board: 3 단계, 이미지 1/1
    • Before assembling it all, it is worth testing the driver board works fine - I had some issues with the Mini Display port to HDMI cable I bought, so returned this and bought a 1M Mini Display port to DVI cable instead which worked fine.
    • I also bought a 1M white HDMI cable to have as an extra input cable for everything else and a 0.5 Metre 2.1mm DC Barrel Extension Cable, to allow me to connect and disconnect the PSU from outside the case.
  4. How to turn a iMac Intel into an External Monitor, Assemble! - Part 2: 4 단계, 이미지 1/2 How to turn a iMac Intel into an External Monitor, Assemble! - Part 2: 4 단계, 이미지 2/2
    • The various mounting posts inside the iMac were not suitable, so I purchased some PCB self-adhesive mounting posts (9.5mm) to mount the driver board, inverter and controller board.
    • To ensure the mounting posts were mounted correctly, I cut squares out of the EMI shielding before attaching the posts to the inner of the iMac casing. I also drilled holes for the power / adjustment board, so the buttons could be accessed from the rear of the machine.
    • From here it was a just a matter of attaching the boards to the PCB posts, hooking up the various cables and feeding through them through the former power in cut-out. I also insulated under the LCD driver board, as it was a bare circuit board. The inverter came contained within a clear plastic case.
    • As with the original setup, the LVDS cable and bottom inverter cables could only be attached with the screen in place.
  5. How to turn a iMac Intel into an External Monitor, Complete!: 5 단계, 이미지 1/2 How to turn a iMac Intel into an External Monitor, Complete!: 5 단계, 이미지 2/2
    • I then reassembled the iMac, attaching the screen, repairing EMI tape then putting the front on! It now works perfectly with the Mini DisplayPort output of my screen-less MacBook Pro and I have an available HDMI cable to attach any other device.
    • The only thing that was not changeable was the CCFL brightness, but using Shades preference pane solves this satisfactorily for me.
  6. How to turn a iMac Intel into an External Monitor, Bonus stage - rear mount MacBook: 6 단계, 이미지 1/2 How to turn a iMac Intel into an External Monitor, Bonus stage - rear mount MacBook: 6 단계, 이미지 2/2
    • To keep everything neat, and as I had a separate keyboard and Magic Mouse, I also wanted to rear mount the Macbook - I created a mount from wood in a similar style to the AluRack, mounting onto the cable hole on the iMac stand - perfect!
  7. How to turn a iMac Intel into an External Monitor, More info on the mount: 7 단계, 이미지 1/3 How to turn a iMac Intel into an External Monitor, More info on the mount: 7 단계, 이미지 2/3 How to turn a iMac Intel into an External Monitor, More info on the mount: 7 단계, 이미지 3/3
    • I have added a few further images of the MacBook mount I made - hopefully they are decipherable / useful!
결론
다른 29명이 해당 안내서를 완성하였습니다.
Michael
회원 가입일: 05/13/16
1,133 평판
안내서 1개 작성함
68 댓글
Hi, Michael!
I found this guide while searching for re-usability of my iMac. I have iMac of late 2006, and I want to use it as an external monitor or as TV.
So, is it possible to make it using this guide?
Thanks.
Kirtan Patel - 답글
Hi there, yes it was a late 2006 model I used, so yes it is possible. I would recommend checking what LCD screen you have inside the iMac first though, then whether you can get a driver board. You can use it with any device with a HDMI/DVI/HDMI output :-)
Michael -
Hello Michael!
I need your help, because Im trying to do the same with my imac, I have all the components, but I am having some issues with the inverter, Can you show me how you connect yours?
Brandon - 답글
Hi Brandon,
What are the problems you are having?
Do you have the exact same looking inverter and controller board? I have some photos of the controller connection to the inverter at both controller and inverter side, would this help?
I have no photos of the inverter cables connected to the inverter though - I do remember that the red dot on the converter cables should be facing you when looking at the inverter board.
Michael -
Can we convert imac display as TV
Vasanthakumar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 77
7일 전: 623
30일 전: 2,892
전체 시간: 107,735
