주요 콘텐츠로 건너뛰기
How to turn an iMac Intel into an External Monitor
  1. How to turn an iMac Intel into an External Monitor, Gut the iMac: 1 단계, 이미지 1개 중 1개
    • Firstly, I completely gutted the iMac, safely keeping the LCD screen to one side. I also repaired any torn EMI shielding and shielded all holes, with the exception of the power in, vent above this. (I also left the 3x USB ports free to fit a USB hub, but this didn't work great, so ended up being removed).
  2. How to turn an iMac Intel into an External Monitor, Find a LCD display driver board: 2 단계, 이미지 1개 중 1개
    • I next found out that my screen was a Samsung LTM201M1-L01 and after scouring eBay with this model number, I managed to find a display driver for this screen from eBay - just search for your screen model number
    • My LCD driver board has VGA, DVI and HDMI in and is powered by a 12V 4A external PSU - the eBay seller also sold PSUs, but I had one kicking about from another LCD screen.
  3. How to turn an iMac Intel into an External Monitor, Test driver board: 3 단계, 이미지 1개 중 1개
    • Before assembling it all, it is worth testing the driver board works fine - I had some issues with the Mini Display port to HDMI cable I bought, so returned this and bought a 1M Mini Display port to DVI cable instead which worked fine.
    • I also bought a 1M white HDMI cable to have as an extra input cable for everything else and a 0.5 Metre 2.1mm DC Barrel Extension Cable, to allow me to connect and disconnect the PSU from outside the case.
  4. How to turn an iMac Intel into an External Monitor, Assemble! - Part 2: 4 단계, 이미지 2개 중 1개 How to turn an iMac Intel into an External Monitor, Assemble! - Part 2: 4 단계, 이미지 2개 중 2개
    • The various mounting posts inside the iMac were not suitable, so I purchased some PCB self-adhesive mounting posts (9.5mm) to mount the driver board, inverter and controller board.
    • To ensure the mounting posts were mounted correctly, I cut squares out of the EMI shielding before attaching the posts to the inner of the iMac casing. I also drilled holes for the power / adjustment board, so the buttons could be accessed from the rear of the machine.
    • From here it was a just a matter of attaching the boards to the PCB posts, hooking up the various cables and feeding through them through the former power in cut-out. I also insulated under the LCD driver board, as it was a bare circuit board. The inverter came contained within a clear plastic case.
    • As with the original setup, the LVDS cable and bottom inverter cables could only be attached with the screen in place.
  5. How to turn an iMac Intel into an External Monitor, Complete!: 5 단계, 이미지 2개 중 1개 How to turn an iMac Intel into an External Monitor, Complete!: 5 단계, 이미지 2개 중 2개
    • I then reassembled the iMac, attaching the screen, repairing EMI tape then putting the front on! It now works perfectly with the Mini DisplayPort output of my screen-less MacBook Pro and I have an available HDMI cable to attach any other device.
    • The only thing that was not changeable was the CCFL brightness, but using Shades preference pane solves this satisfactorily for me.
  6. How to turn an iMac Intel into an External Monitor, Bonus stage - rear mount MacBook: 6 단계, 이미지 2개 중 1개 How to turn an iMac Intel into an External Monitor, Bonus stage - rear mount MacBook: 6 단계, 이미지 2개 중 2개
    • To keep everything neat, and as I had a separate keyboard and Magic Mouse, I also wanted to rear mount the Macbook - I created a mount from wood in a similar style to the AluRack, mounting onto the cable hole on the iMac stand - perfect!
  7. How to turn an iMac Intel into an External Monitor, More info on the mount: 7 단계, 이미지 3개 중 1개 How to turn an iMac Intel into an External Monitor, More info on the mount: 7 단계, 이미지 3개 중 2개 How to turn an iMac Intel into an External Monitor, More info on the mount: 7 단계, 이미지 3개 중 3개
    • I have added a few further images of the MacBook mount I made - hopefully they are decipherable / useful!
결론
다른 35명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Michael
회원 가입일: 05/13/16
1,355 평판
안내서 1개를 작성함
77가이드 댓글
Hi, Michael!
I found this guide while searching for re-usability of my iMac. I have iMac of late 2006, and I want to use it as an external monitor or as TV.
So, is it possible to make it using this guide?
Thanks.
Kirtan Patel - 답글
Hi there, yes it was a late 2006 model I used, so yes it is possible. I would recommend checking what LCD screen you have inside the iMac first though, then whether you can get a driver board. You can use it with any device with a HDMI/DVI/HDMI output :-)
Michael -
Hello Michael!
I need your help, because Im trying to do the same with my imac, I have all the components, but I am having some issues with the inverter, Can you show me how you connect yours?
Brandon - 답글
Hi Brandon,
What are the problems you are having?
Do you have the exact same looking inverter and controller board? I have some photos of the controller connection to the inverter at both controller and inverter side, would this help?
I have no photos of the inverter cables connected to the inverter though - I do remember that the red dot on the converter cables should be facing you when looking at the inverter board.
Michael -
Can we convert imac display as TV
Vasanthakumar - 답글
댓글 쓰기
조회 통계:
지난 24시간: 67
지난 7일: 456
지난 30일: 2,069
전체 시간: 170,010
