주요 콘텐츠로 건너뛰기
How to un-crease the toe box of a shoe
필요한 것
  1. How to un-crease the toe box of a shoe, How to un-crease the toe box of a shoe: 1 단계, 이미지 1개 중 1개
    • Gather all the materials (Shoes, 2 washcloths, 2 old t-shirts, an iron, a cup of water)
  2. How to un-crease the toe box of a shoe: 2 단계, 이미지 1개 중 1개
    • Remove the laces off of your shoe.
  3. How to un-crease the toe box of a shoe: 3 단계, 이미지 1개 중 1개
    • Insert one of your old t-shirts into the front of the shoe in order to stuff the toe box.
  4. How to un-crease the toe box of a shoe: 4 단계, 이미지 1개 중 1개
    • Fill your iron with water.
    • Make sure that the iron is unplugged while you fill it.
  5. How to un-crease the toe box of a shoe: 5 단계, 이미지 2개 중 1개 How to un-crease the toe box of a shoe: 5 단계, 이미지 2개 중 2개
    • Place a washcloth on top of your shoe.
    • Carefully iron the area with the creases in a circular motion.
  6. How to un-crease the toe box of a shoe: 7 단계, 이미지 1개 중 1개
    • After ironing, let the shoe rest with the cloth on top for at least 2 minutes.
  7. How to un-crease the toe box of a shoe: 8 단계, 이미지 1개 중 1개
    • You are done! The shoe's creases should have been greatly reduced.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Rohit Ark
회원 가입일: 05/04/20
205 평판
안내서 1개를 작성함
1가이드 댓글
How long should I iron the area for?
Caydon Bridge - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 43
전체 시간: 7,058
