주요 콘텐츠로 건너뛰기
How to unlock developer options on an Android Phone
  1. How to unlock developer options on an Android Phone, Finding the Build Number: 1 단계, 이미지 3개 중 1개 How to unlock developer options on an Android Phone, Finding the Build Number: 1 단계, 이미지 3개 중 2개 How to unlock developer options on an Android Phone, Finding the Build Number: 1 단계, 이미지 3개 중 3개
    • First, we need to find the Build Number.
    • Usually you can find it under About Phone > Build Number or System > About Phone > Build Number, but since it varies from device to device using the search function is usually the easiest way.
  2. How to unlock developer options on an Android Phone, Unlocking developer options: 2 단계, 이미지 2개 중 1개 How to unlock developer options on an Android Phone, Unlocking developer options: 2 단계, 이미지 2개 중 2개
    • Now you just need to tap the Build number repeatedly, until you get a confirmation message saying "You are now a developer!". I already enabled developer options on my device, so I don’t need to do it again.
    • You might be prompted to enter your lock screen password, if you have one set up.
결론
다른 21명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sebastian
회원 가입일: 08/19/18
31,191 평판
안내서 71개를 작성함
5가이드 댓글
Ma batterie durée avant même maintenant ça dure plus
Konan Alain - 답글
Je ne comprends pas très bien la question, mais normalement, le déverrouillage des options de développement ne devrait pas affecter la durée de vie de votre batterie.
Sebastian -
The developer option is disabled how do you enable it again
Donelle - 답글
Mera build number nahi kholraha hai
Rajkumari sahu - 답글
Svp je demande à une bonne volonté de déverrouiller le MDM dans mon téléphone Android Infinix Hot 50 pro+
DRABO Issouf - 답글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 116
지난 30일: 414
전체 시간: 10,405
