주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Prerequisite guide for safely powering down your PC before opening it for maintenance or repair.
  1. Power down your PC and remove the power cord from the back. Power down your PC and remove the power cord from the back.
    • Power down your PC and remove the power cord from the back.
  2. Press and hold the power button for about 10 seconds, then release. This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
결론
Now you can start doing repairs on it.
다른 한 분이 해당 안내서를 완성하였습니다.
Padraic Hoselton
회원 가입일: 2017년 08월 22일
3,451 평판
안내서 13개 작성하였습니다
Master Techs Master Techs 회원
Community
294 회원들
안내서 962개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 47
