주요 콘텐츠로 건너뛰기
How to use a Krone LSA-Plus Punchdown Tool
필요한 것
  1. How to use a Krone LSA-Plus Punchdown Tool, LSA vs. LSA Plus: 1 단계, 이미지 2개 중 1개 How to use a Krone LSA-Plus Punchdown Tool, LSA vs. LSA Plus: 1 단계, 이미지 2개 중 2개
    • There is a difference between LSA and LSA Plus:
    • LSA: The insulation displacement terminals are perpendicular to the cable.
    • LSA Plus: With this technology, the insulation displacement connectors are at an angle of 45° to the cable.
  2. How to use a Krone LSA-Plus Punchdown Tool, Switch the scissors on/off: 2 단계, 이미지 1개 중 1개
    • The Krone tool has integrated scissors that automatically cut the excess when you punch down the wire.
    • To enable or disable the scissors, turn the wheel in the middle of the tool.
  3. How to use a Krone LSA-Plus Punchdown Tool, Switch the sensor on/off: 3 단계, 이미지 2개 중 1개 How to use a Krone LSA-Plus Punchdown Tool, Switch the sensor on/off: 3 단계, 이미지 2개 중 2개
    • The sensor is a mechanism that only allows the scissors to work if the tool is properly inserted into the LSA slot. You might want to disable it if you want to connect two wires on one contact (requires special contact).
    • To disable the sensor, move the metal bracket at the front of the tool towards the toolhead.
  4. How to use a Krone LSA-Plus Punchdown Tool, Place your cable: 4 단계, 이미지 1개 중 1개
    • Place the cable you want to punch down into the terminal.
  5. How to use a Krone LSA-Plus Punchdown Tool, Punch down: 5 단계, 이미지 2개 중 1개 How to use a Krone LSA-Plus Punchdown Tool, Punch down: 5 단계, 이미지 2개 중 2개
    • Press down on the connector.
    • LSA-Plus is directionally keyed. If your tool doesn't enter into the gap, it might be because you're holding it the wrong way around.
  6. How to use a Krone LSA-Plus Punchdown Tool, Cut the excess: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Flush Cutter
    $29.99
    • If your scissors are off, or you're working in a tight space where the excess left by the tool might be too much you'll have to manually trim the excess.
    • Use electronics sidecutters to trim the excess.
  7. How to use a Krone LSA-Plus Punchdown Tool, Remove a connection: 7 단계, 이미지 3개 중 1개 How to use a Krone LSA-Plus Punchdown Tool, Remove a connection: 7 단계, 이미지 3개 중 2개 How to use a Krone LSA-Plus Punchdown Tool, Remove a connection: 7 단계, 이미지 3개 중 3개
    • Press on the tab to release the wire removal hook.
    • Use the hook to pull out the wire you want to remove.
결론
Good luck on your next project!
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sebastian
회원 가입일: 08/19/18
31,221 평판
안내서 71개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 17
지난 7일: 104
지난 30일: 465
전체 시간: 10,011
