주요 콘텐츠로 건너뛰기
How to use and maintain your bread maker
필요한 것
    • Rely on the recipe booklet that came with the bread maker and follow the listed quantities exactly.
    • Keep the booklet in a safe place because losing it makes precise baking difficult.
    • Confirm that the kneading paddle, baking pan, and pan‑removal hook are present and undamaged.
    • Measuring wrongly or skipping ingredients will cause poor loaf quality.
    • Fit the kneading paddle onto the pan shaft firmly so it does not come loose during mixing.
    • Lightly coat the inside of the pan and the paddle with a thin layer of oil or other non‑stick grease.
    • Proper greasing lets the finished loaf and paddle release cleanly.
    • Pour all required liquids into the greased pan first.
    • Add oil or fat if the recipe calls for it, keeping it separate from the yeast.
    • Tip the measured flour on top of the liquid to form a dry layer.
    • Place yeast last, on top of the flour, especially when using the delayed‑start timer.
    • Incorrect order or wet yeast can cause premature fermentation and collapsed bread.
    • Lower the loaded pan into the chamber and lock it until it clicks.
    • Select the program that matches the recipe, such as Basic.
    • Choose loaf size and crust color as desired.
    • Activate the delayed‑start option only after confirming yeast is dry and above flour.
    • Close the lid and allow the machine to complete kneading, rising, and baking without opening it.
    • When the cycle ends the bread maker keeps the loaf warm for up to one hour.
    • Remove the loaf within that hour because extended holding makes the crust soggy.
    • Use the supplied hook or heat‑safe gloves to lift the hot pan straight out.
    • Turn the pan upside down and gently shake until the loaf slides free.
    • If greased correctly, the kneading paddle should stay in or fall out cleanly with the bread.
    • Place the loaf on a wire rack to cool before slicing.
    • The bread maker’s dedicated program can cook jam or marmalade from fruit and sugar.
    • Even first‑time users can obtain tasty results by following the machine’s jam recipe.
    • Unplug the bread maker and let it cool completely before cleaning.
    • Wipe the interior and exterior surfaces with a soft, dry or slightly damp cloth.
    • Do not immerse the machine or let water enter the heating chamber.
    • Remove crumbs or flour from the lid, seal, and around the pan supports.
    • Store the pan and paddle dry to prevent corrosion.
    • Keep the bread maker on a stable surface or store it in a dry cupboard when not in use.
    • Regularly grease the pan lightly to maintain the non‑stick layer.
    • Follow the manufacturer’s instructions to avoid actions that could void the warranty.
결론
By measuring accurately, loading ingredients in the right order, and cleaning gently after each bake, you will enjoy reliable loaves and protect the appliance for years. Always unplug before maintenance and defer complex repairs to qualified professionals.
작성자
2다른 기여자 명과 함께
Ula Gantar
회원 가입일: 01/08/25
16,474 평판
안내서 48개를 작성함
ZEOS Slovenia ZEOS Slovenia 회원
Local Repair Groups
2 회원들
안내서 56개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 47
