주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to wind back the EPB, electronic parking brake, to change rear brake pads
필요한 것
동영상 개요
    • Insert wisdom here.
    댓글 쓰기
결론
Just follow the video for how to change the rear pads on cars fitted with EPB. This is on a Discovery Sport but applies to others.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
jon
회원 가입일: 05/15/16
3,384 평판
안내서 22개를 작성함
4가이드 댓글
Excellent tutorial, clear and easy to follow, perfect if you are a novice, looking for the same for the front pads now.
alanmac28@tiscali.co.uk - 답글 공유
The front pads should be a lot easier because there’s no awkward handbrake to deal with just push back the caliper pistons with a long screwdriver pushing it evenly both sides.
jon - 답글 공유
You can also rewind them using a 12v source rather than taking the cover off (I was worried on my scenic that it might leak if I broke the seal). The cars know when to stop winding as they sence the current increase when the motor jams. We humans can just use our ears. As long as you take the wire off the battery the very second the motor stops you’ll be fine.
Here is me doing mine this weekend.
https://youtu.be/kGn7tEjr600
James Taylor - 답글 공유
Discover 150cc bike shocker problem how to repair
Md Shahid - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 28
지난 30일: 114
전체 시간: 42,990
