주요 콘텐츠로 건너뛰기
Hp 15-f305dx Hard Drive Replacement
필요한 것
  1. Hp 15-f305dx Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
  2. Hp 15-f305dx Hard Drive Replacement: 2 단계, 이미지 1/1
    • Turn the computer upside down on a flat surface.
  3. Hp 15-f305dx Hard Drive Replacement: 3 단계, 이미지 1/3 Hp 15-f305dx Hard Drive Replacement: 3 단계, 이미지 2/3 Hp 15-f305dx Hard Drive Replacement: 3 단계, 이미지 3/3
    • Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
  4. Hp 15-f305dx Hard Drive Replacement: 4 단계, 이미지 1/2 Hp 15-f305dx Hard Drive Replacement: 4 단계, 이미지 2/2
    • Lift the battery from the middle and then pivot it outward to remove it from the computer.
  5. Hp 15-f305dx Hard Drive Replacement, Keyboard: 5 단계, 이미지 1/1
    • Flip the laptop around.
  6. Hp 15-f305dx Hard Drive Replacement: 6 단계, 이미지 1/2 Hp 15-f305dx Hard Drive Replacement: 6 단계, 이미지 2/2
    • Remove the single 7 mm screw from the top middle of the laptop using a Phillips #0 screwdriver.
  7. Hp 15-f305dx Hard Drive Replacement: 7 단계, 이미지 1/2 Hp 15-f305dx Hard Drive Replacement: 7 단계, 이미지 2/2
    • Pry the keyboard out of the laptop gently and flip the keyboard around.
  8. Hp 15-f305dx Hard Drive Replacement: 8 단계, 이미지 1/1
    • Disconnect the connected cable from the mainboard.
  9. Hp 15-f305dx Hard Drive Replacement, Hard Drive: 9 단계, 이미지 1/2 Hp 15-f305dx Hard Drive Replacement, Hard Drive: 9 단계, 이미지 2/2
    • Remove the twelve screws from the bottom of the laptop with the Philips #0 Screwdriver.
  10. Hp 15-f305dx Hard Drive Replacement: 10 단계, 이미지 1/3 Hp 15-f305dx Hard Drive Replacement: 10 단계, 이미지 2/3 Hp 15-f305dx Hard Drive Replacement: 10 단계, 이미지 3/3
    • Eject the CD player on the side of the laptop by sliding it out.
  11. Hp 15-f305dx Hard Drive Replacement: 11 단계, 이미지 1/3 Hp 15-f305dx Hard Drive Replacement: 11 단계, 이미지 2/3 Hp 15-f305dx Hard Drive Replacement: 11 단계, 이미지 3/3
    • Use a Phillips # 1 Screwdriver to unscrew the three screws under the CD player
  12. Hp 15-f305dx Hard Drive Replacement: 12 단계, 이미지 1/3 Hp 15-f305dx Hard Drive Replacement: 12 단계, 이미지 2/3 Hp 15-f305dx Hard Drive Replacement: 12 단계, 이미지 3/3
    • Flip the device around and open it. Use the blue spudger tool to remove the casing around the keyboard space by driving it the crease and propping it up.
    • Once you have used the spudger tool all the way around the casing, lift the casing up from the device.
  13. Hp 15-f305dx Hard Drive Replacement: 13 단계, 이미지 1/2 Hp 15-f305dx Hard Drive Replacement: 13 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the screw that holds the USB drive in the bottom right corner near the hard drive. Once removed, lift the USB drive off of the hard drive.
  14. Hp 15-f305dx Hard Drive Replacement: 14 단계, 이미지 1/3 Hp 15-f305dx Hard Drive Replacement: 14 단계, 이미지 2/3 Hp 15-f305dx Hard Drive Replacement: 14 단계, 이미지 3/3
    • Lift the hard drive from the device and unconnect the cord attached to it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Brandon
회원 가입일: 03/23/18
681 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S2-G3, Bernier Spring 2018 UMass Dartmouth, Team S2-G3, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S2G3
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 23
전체 시간: 4,266
