주요 콘텐츠로 건너뛰기
Hp 15-f305dx Keyboard Replacement
필요한 것
  1. Hp 15-f305dx Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
  2. Hp 15-f305dx Keyboard Replacement: 2 단계, 이미지 1/1
    • Turn the computer upside down on a flat surface.
  3. Hp 15-f305dx Keyboard Replacement: 3 단계, 이미지 1/3 Hp 15-f305dx Keyboard Replacement: 3 단계, 이미지 2/3 Hp 15-f305dx Keyboard Replacement: 3 단계, 이미지 3/3
    • Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
  4. Hp 15-f305dx Keyboard Replacement: 4 단계, 이미지 1/2 Hp 15-f305dx Keyboard Replacement: 4 단계, 이미지 2/2
    • Lift the battery from the middle and then pivot it outward to remove it from the computer.
  5. Hp 15-f305dx Keyboard Replacement, Keyboard: 5 단계, 이미지 1/1
    • Flip the laptop around.
  6. Hp 15-f305dx Keyboard Replacement: 6 단계, 이미지 1/2 Hp 15-f305dx Keyboard Replacement: 6 단계, 이미지 2/2
    • Remove the single 7 mm screw from the top middle of the laptop using a Phillips #0 screwdriver.
  7. Hp 15-f305dx Keyboard Replacement: 7 단계, 이미지 1/2 Hp 15-f305dx Keyboard Replacement: 7 단계, 이미지 2/2
    • Pry the keyboard out of the laptop gently and flip the keyboard around.
  8. Hp 15-f305dx Keyboard Replacement: 8 단계, 이미지 1/1
    • Disconnect the connected cable from the mainboard.
결론
Brandon
회원 가입일: 03/23/18
681 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S2-G3, Bernier Spring 2018 UMass Dartmouth, Team S2-G3, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S2G3
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 656
