주요 콘텐츠로 건너뛰기
Hp 15-f305dx Screen Replacement
필요한 것
  1. Hp 15-f305dx Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
  2. Hp 15-f305dx Screen Replacement: 2 단계, 이미지 1/1
    • Turn the computer upside down on a flat surface.
  3. Hp 15-f305dx Screen Replacement: 3 단계, 이미지 1/3 Hp 15-f305dx Screen Replacement: 3 단계, 이미지 2/3 Hp 15-f305dx Screen Replacement: 3 단계, 이미지 3/3
    • Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
  4. Hp 15-f305dx Screen Replacement: 4 단계, 이미지 1/2 Hp 15-f305dx Screen Replacement: 4 단계, 이미지 2/2
    • Lift the battery from the middle and then pivot it outward to remove it from the computer.
  5. Hp 15-f305dx Screen Replacement, Screen: 5 단계, 이미지 1/3 Hp 15-f305dx Screen Replacement, Screen: 5 단계, 이미지 2/3 Hp 15-f305dx Screen Replacement, Screen: 5 단계, 이미지 3/3
    • Remove the bezel by prying it away from the screen using the spudger.
    • Note: Some models may have two screws hidden behind round covers in the lower section of the bezel.
  6. Hp 15-f305dx Screen Replacement: 6 단계, 이미지 1/1
    • Remove the four 3mm PH1 Phillips head screws in each corner of the screen and do not care about outer screws.
  7. Hp 15-f305dx Screen Replacement: 7 단계, 이미지 1/1
    • Remove the screen and place the screen very softly on the keyboard.
  8. Hp 15-f305dx Screen Replacement: 8 단계, 이미지 1/2 Hp 15-f305dx Screen Replacement: 8 단계, 이미지 2/2
    • Remove the sticker gently and disconnect the metal blade.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brandon
회원 가입일: 03/23/18
681 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S2-G3, Bernier Spring 2018 UMass Dartmouth, Team S2-G3, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S2G3
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 664
