소개
A easy replacement of hard disk on a HP Mini 2133.
Remove the screws
And open it up
Then disconect the cable for the key board.
Now disconect the cable under the keyboard.
ATTENTION There is a lever to disconect the keyboard.
Now remove the protector.
The black screw does not come off completely.
Now you remove the conector from the disk.
CAUTION WITH THE CONECTOR!
Para reensamblar tu dispositivo, sigue estas instrucciones en orden inverso.
다른 한 분이 해당 안내서를 완성하였습니다.
