주요 콘텐츠로 건너뛰기
Hp Pavilion A600 Hdd Replacement
필요한 것
  1. Hp Pavilion A600 Hdd Replacement, Hdd: 1 단계, 이미지 2개 중 1개 Hp Pavilion A600 Hdd Replacement, Hdd: 1 단계, 이미지 2개 중 2개
    • first take out the Phillips screw out of the side panel and then take off the side panel.
  2. Hp Pavilion A600 Hdd Replacement: 2 단계, 이미지 2개 중 1개 Hp Pavilion A600 Hdd Replacement: 2 단계, 이미지 2개 중 2개
    • After you do that then unscrew the two Phillips types screws holding in the HDD deck by the front panel.
  3. Hp Pavilion A600 Hdd Replacement, Pop out the deck: 3 단계, 이미지 3개 중 1개 Hp Pavilion A600 Hdd Replacement, Pop out the deck: 3 단계, 이미지 3개 중 2개 Hp Pavilion A600 Hdd Replacement, Pop out the deck: 3 단계, 이미지 3개 중 3개
    • Once you've done that then push the button down closer to the logic board right next to it the HDD deck and slide it to the right and pop it out.
  4. Hp Pavilion A600 Hdd Replacement, Taking  the HDD out: 4 단계, 이미지 3개 중 1개 Hp Pavilion A600 Hdd Replacement, Taking  the HDD out: 4 단계, 이미지 3개 중 2개 Hp Pavilion A600 Hdd Replacement, Taking  the HDD out: 4 단계, 이미지 3개 중 3개
    • Unscrew the four screws holding the HDD in then take that unplug it and then take it out of the deck.
  5. Hp Pavilion A600 Hdd Replacement, Putting the new one in: 5 단계, 이미지 3개 중 1개 Hp Pavilion A600 Hdd Replacement, Putting the new one in: 5 단계, 이미지 3개 중 2개 Hp Pavilion A600 Hdd Replacement, Putting the new one in: 5 단계, 이미지 3개 중 3개
    • Once you finish taking it then get your new HDD and then put it back in threw it back in the the deck put it back in the whole thing back in you're done hope you liked it like it thanks bye.
    • thanks please like if you want more of these HDD teardown stuff then if you want me to show you how to modify this same with the floppy disk drive I will glad you guys if you guys
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
McOfficialPlayYT
회원 가입일: 02/28/17
436 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 197
