소개
Replaceing your hdd
필요한 것
Once you've done that then push the button down closer to the logic board right next to it the HDD deck and slide it to the right and pop it out.
Unscrew the four screws holding the HDD in then take that unplug it and then take it out of the deck.
Once you finish taking it then get your new HDD and then put it back in threw it back in the the deck put it back in the whole thing back in you're done hope you liked it like it thanks bye.
thanks please like if you want more of these HDD teardown stuff then if you want me to show you how to modify this same with the floppy disk drive I will glad you guys if you guys
다른 3명이 해당 안내서를 완성하였습니다.
