소개
In this guide, you will learn how to safely remove the head phone and ear phone jack from your laptop.
필요한 것
Remove the six screws. Four are marked with a keyboard icons, two are located on the top corner.
Remove the three screws located in the battery port.
Flip the laptop over and locate the memory module panel and loosen the 3 screws holding down the panel.
Remove the panel to expose the 2 memory modules.
Remove the memory modules by using your index finger and thumb to spread apart the silver retaining tabs on both sides of the modules. After spreading the tabs apart, lift and pull the module out at an angle.
Repeat this action for the second memory module that is directly under the first.
Locate the WLAN module located in the hard drive panel and remove the single silver screw holding the WLAN module.
After screw is removed, gently disconnect the WLAN module using your thumb and index finger from the connector.
Disconnect the two WLAN antenna cables (white and black) attached to the WLAN module by gently lifting and holding onto the gold base.
