주요 콘텐츠로 건너뛰기
Hp Pavilion dv6-2155dx Keyboard Replacement
필요한 것
  1. Hp Pavilion dv6-2155dx Keyboard Replacement, Hard Drive: 1 단계, 이미지 2개 중 1개 Hp Pavilion dv6-2155dx Keyboard Replacement, Hard Drive: 1 단계, 이미지 2개 중 2개
    • Shutdown your computer and remove the battery before beginning the replacement.
    • Loosen the screws using Phillips #01 screwdriver with the extension attached.
    • The screws will not come out completely but stay on the panel.
  2. Hp Pavilion dv6-2155dx Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • After removing the two screws securing the Hard Drive to the bottom case, remove the panel to reveal the hard drive.
  3. Hp Pavilion dv6-2155dx Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Hp Pavilion dv6-2155dx Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Locate the tab of the black Mylar film on the right hand side of the hard drive.
    • Gently grip it with your thumb and index finger.
  4. Hp Pavilion dv6-2155dx Keyboard Replacement: 4 단계, 이미지 2개 중 1개 Hp Pavilion dv6-2155dx Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Pull the Hard Drive to the right to loosen the it from the frame.
    • The left side of the hard drive will pop up and should slide out freely until you see the black connector on it's right side, connecting it to the computer.
  5. Hp Pavilion dv6-2155dx Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Hp Pavilion dv6-2155dx Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • When removing the Hard Drive from the frame, you will see a black connector on it's right side.
    • Turn the Hard Drive over and grasp the Hard Drive with one hand as you grip the connector with the other hand to remove the connector from the hard drive.
    • To safely remove the Hard Driver, do not wiggle or jerk the connector off of the Hard Drive, pull straight off.
  6. Hp Pavilion dv6-2155dx Keyboard Replacement, Keyboard: 6 단계, 이미지 1개 중 1개
    • Remove the six screws. Four are marked with a keyboard icons, two are located on the top corner.
    • Remove the three screws located in the battery port.
    • Red marked screws: 7mm long and the head is 4mm wide. Orange marked screws: 4mm long and head is 4mm wide.
  7. Hp Pavilion dv6-2155dx Keyboard Replacement: 7 단계, 이미지 2개 중 1개 Hp Pavilion dv6-2155dx Keyboard Replacement: 7 단계, 이미지 2개 중 2개
    • Use a plastic spudger to gently un-clip the top panel above keyboard.
    • Tab openings are located by the F1 key, F5 key, and page up key
    • Once loose, do not try and remove it completely
  8. Hp Pavilion dv6-2155dx Keyboard Replacement: 8 단계, 이미지 2개 중 1개 Hp Pavilion dv6-2155dx Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Once the top panel is propped open, remove the three 4mm silver screws located at the top of the keyboard with a Philips head screw driver, size #1.
    • Flip keyboard forward and raise the keyboard off the frame.
    • Be careful not to prop the top panel up too high as to disconnect the two ribbons connecting it to the inside of the laptop.
  9. Hp Pavilion dv6-2155dx Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    • Once you have removed the three screws, gently lift the keyboard away from the laptop.
    • Be careful when lifting the keyboard as to not break or damage the ribbon cable that connects the keyboard to the laptop.
  10. Hp Pavilion dv6-2155dx Keyboard Replacement: 10 단계, 이미지 2개 중 1개 Hp Pavilion dv6-2155dx Keyboard Replacement: 10 단계, 이미지 2개 중 2개
    • Use plastic spudger to flip up the black strip on the ZIF connector that connects the ribbon cable to the motherboard.
    • Be sure to flip the hinge retaining flap, not pulling the connector itself.
  11. Hp Pavilion dv6-2155dx Keyboard Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the film from system board to then safely remove the keyboard.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Joseph Sanda
회원 가입일: 03/10/16
522 평판
안내서 4개를 작성함
UMass Dartmouth, Team 2-2, Isaacson Fall 2016 UMass Dartmouth, Team 2-2, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G2
3 회원들
안내서 5개를 작성함
1가이드 댓글
Awesome....worked perfectly.
mastover - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 24
전체 시간: 2,346
