주요 콘텐츠로 건너뛰기
Hp Pavilion dv6-2155dx Optical Drive Replacement
필요한 것
  1. Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: 1 단계, 이미지 2개 중 1개 Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: 1 단계, 이미지 2개 중 2개
    • Flip the computer around to the back side.
    • Remove the three screws from the memory module cover.
    • Screws will not come out all the way.
    • All screws to loosen/removed in this guide will require a Phillips #01 screwdriver.
  2. Hp Pavilion dv6-2155dx Optical  Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the screw completely from the memory module panel to help release the Optical drive from the body of the computer.
    • The screw is 7mm long and head is 4mm wide.
  3. Hp Pavilion dv6-2155dx Optical  Drive Replacement: 3 단계, 이미지 2개 중 1개 Hp Pavilion dv6-2155dx Optical  Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Locate the small hole next to the eject button.
    • Get a paper clip and insert in to the small hole until you hear a clicking sound and seeing the tray pop out.
    • Before removing the optical drive, be sure that there is nothing in the drive. Optical drives are fragile so handle with care.
  4. Hp Pavilion dv6-2155dx Optical  Drive Replacement: 4 단계, 이미지 2개 중 1개 Hp Pavilion dv6-2155dx Optical  Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Gently pull the Optical drive out of the slot until the whole thing comes out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Joseph Sanda
회원 가입일: 03/10/16
522 평판
안내서 4개를 작성함
UMass Dartmouth, Team 2-2, Isaacson Fall 2016 UMass Dartmouth, Team 2-2, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G2
3 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 832
