주요 콘텐츠로 건너뛰기
Huawei Ascend G510 disassembly
필요한 것
  1. Huawei Ascend G510 disassembly, Huawei ascend g510: 1 단계, 이미지 1/1
    • My friend gave me it for 5€ (broken lcd and touch) so i took it apart
    • Yours may look different but tutorial like this should help you anyway :)
  2. Huawei Ascend G510 disassembly: 2 단계, 이미지 1/1
    • That's back of Huawei ascend g510
    • It's Inexpensive android phone
    • To open pry left down corner
    • You don't need any tools for this... You can pry any corner to pop the back open
  3. Huawei Ascend G510 disassembly: 3 단계, 이미지 1/1
    • First remove battery
  4. Huawei Ascend G510 disassembly, The battery: 4 단계, 이미지 1/2 Huawei Ascend G510 disassembly, The battery: 4 단계, 이미지 2/2
    • It's HB4W1H 3.7v 1750mAh (6.5Wh) Li-ion battery
    • Don't mess with Lithium ion batteries... (And don't take apart)
    • MADE IN CHINA... As everything
  5. Huawei Ascend G510 disassembly: 5 단계, 이미지 1/1
    • There are
    • 7 black T5 screws
    • 1 white T5 screw
    • 1 black Philipps #0 screw
    • Just remove all and sort them so you don't mix them
  6. Huawei Ascend G510 disassembly: 6 단계, 이미지 1/1
    • There are many clips along the sides
    • Don't pry to hard or you'll break some plastic
    • These clips really suck
  7. Huawei Ascend G510 disassembly: 7 단계, 이미지 1/1
    • First undo all connectors (lcd, touch, camera, sim/sd slot)
    • Main PCB is hold with clips and glue
    • Really frustrating to remove it... Glue or clips are everywhere
  8. Huawei Ascend G510 disassembly, The camera: 8 단계, 이미지 1/1
    • That's the camera
  9. Huawei Ascend G510 disassembly, The PCB: 9 단계, 이미지 1/2 Huawei Ascend G510 disassembly, The PCB: 9 단계, 이미지 2/2
    • Let's take look at pcb.
    • Unmodular and crusty... I don't like it at all
  10. Huawei Ascend G510 disassembly, The PCB (back): 10 단계, 이미지 1/2 Huawei Ascend G510 disassembly, The PCB (back): 10 단계, 이미지 2/2
    • As bad as front
  11. Huawei Ascend G510 disassembly: 11 단계, 이미지 1/2 Huawei Ascend G510 disassembly: 11 단계, 이미지 2/2
    • To separate glass (with touch) just heat it up to loosen adhesive
결론
다른 17명이 해당 안내서를 완성하였습니다.
Mateusz
회원 가입일: 10/20/14
1,498 평판
안내서 2개 작성하였습니다
댓글 3개
It just won't read my sim card,i was wondering if there is a setting that has been changed?
Michael Cummins - 답글
I have a good idea of what you are doing and how much you are doing. I have a nice day ahead of the individual named recipient
Dear sir
My phone huawei G510 runs but the display light is not coming please can u give me some suggestion how to repair it
sak - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 5,626
