주요 콘텐츠로 건너뛰기
소개
Complete replacement of the assembled frame and touch screen display.
  1. Huawei Ascend G610 Display Assembly  Replacement, Display Assembly: 1 단계, 이미지 1/1
    • Remove the back cover.
  2. Huawei Ascend G610 Display Assembly  Replacement: 2 단계, 이미지 1/1
    • Remove the battery.
  3. Huawei Ascend G610 Display Assembly  Replacement: 3 단계, 이미지 1/3 Huawei Ascend G610 Display Assembly  Replacement: 3 단계, 이미지 2/3 Huawei Ascend G610 Display Assembly  Replacement: 3 단계, 이미지 3/3
    • With the help of a cross-head screwdriver, remove the 9 side screws that secure the back cover.
    • Note: 1 of these screws is covered by an adhesive label.
    • Remove the central screw next to the SIM card slot. Note: it's the shortest screw.
  4. Huawei Ascend G610 Display Assembly  Replacement: 4 단계, 이미지 1/2 Huawei Ascend G610 Display Assembly  Replacement: 4 단계, 이미지 2/2
    • Disconnect the display connector.
  5. Huawei Ascend G610 Display Assembly  Replacement: 5 단계, 이미지 1/2 Huawei Ascend G610 Display Assembly  Replacement: 5 단계, 이미지 2/2
    • Disconnect the ambient light sensor.
  6. Huawei Ascend G610 Display Assembly  Replacement: 6 단계, 이미지 1/2 Huawei Ascend G610 Display Assembly  Replacement: 6 단계, 이미지 2/2
    • Unplug the touch screen connector.
  7. Huawei Ascend G610 Display Assembly  Replacement: 7 단계, 이미지 1/2 Huawei Ascend G610 Display Assembly  Replacement: 7 단계, 이미지 2/2
    • Unplug the connector that joins the two boards.
  8. Huawei Ascend G610 Display Assembly  Replacement: 8 단계, 이미지 1/3 Huawei Ascend G610 Display Assembly  Replacement: 8 단계, 이미지 2/3 Huawei Ascend G610 Display Assembly  Replacement: 8 단계, 이미지 3/3
    • Unplug the main motherboard that is secured at 3 points.
  9. Huawei Ascend G610 Display Assembly  Replacement: 9 단계, 이미지 1/3 Huawei Ascend G610 Display Assembly  Replacement: 9 단계, 이미지 2/3 Huawei Ascend G610 Display Assembly  Replacement: 9 단계, 이미지 3/3
    • With the help of a heater, heat the board attached with double-sided adhesive tape.
    • With a thin tool, gently pry underneath the adhesive until it is fully detached.
  10. Huawei Ascend G610 Display Assembly  Replacement: 10 단계, 이미지 1/2 Huawei Ascend G610 Display Assembly  Replacement: 10 단계, 이미지 2/2
    • Remove the housed microphone.
  11. Huawei Ascend G610 Display Assembly  Replacement: 11 단계, 이미지 1/3 Huawei Ascend G610 Display Assembly  Replacement: 11 단계, 이미지 2/3 Huawei Ascend G610 Display Assembly  Replacement: 11 단계, 이미지 3/3
    • Using the phone for leverage, remove the flat volume keys and turn off the device.
  12. Huawei Ascend G610 Display Assembly  Replacement: 12 단계, 이미지 1/2 Huawei Ascend G610 Display Assembly  Replacement: 12 단계, 이미지 2/2
    • Remove the speaker.
  13. Huawei Ascend G610 Display Assembly  Replacement: 13 단계, 이미지 1/2 Huawei Ascend G610 Display Assembly  Replacement: 13 단계, 이미지 2/2
    • Remove the ambient light sensor.
  14. Huawei Ascend G610 Display Assembly  Replacement: 14 단계, 이미지 1/1
    • Remove the unique adhesive label on the phone.
  15. Huawei Ascend G610 Display Assembly  Replacement: 15 단계, 이미지 1/1
    • Now, reassemble the pieces on the new display assembly with the frame and touch screen by reversing the steps of this guide.
결론
To reassemble the device, follow these instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
it en
100%
Ben Johnson님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Smilzo
회원 가입일: 2013년 11월 09일
10,335 평판
안내서 39개 작성하였습니다
댓글 4개
Hi. Do you follow this procedure to replace a shattered screen? Where can I get the specialised little plastic tools designed to do this? Interesting. Thank.J.
jessemark05 - 답글
hello, generally the tools are found together with the new display that you buy.  otherwise you can buy them online or at ifixit shop
Smilzo -
Got the tools needed,thanks for reply. Do I have to follow this complete procedure just to replace the screen? Jesse.
jessemark05 - 답글
yes, this is the procedure to replace the complete frame display
Smilzo -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 2,158
