주요 콘텐츠로 건너뛰기
소개
Follow this repair guide if you have problems with the brightness sensor in your device
  1. Huawei Ascend G610 Replacement proximity brightness sensor, Proximity brightness sensor: 1 단계, 이미지 1/1
    • Remove back cover
  2. Huawei Ascend G610 Replacement proximity brightness sensor: 2 단계, 이미지 1/1
    • Remove battery
  3. Huawei Ascend G610 Replacement proximity brightness sensor: 3 단계, 이미지 1/1
    • With the help of a Phillips screwdriver, remove the 9 side screws, one is located under the adhesive
  4. Huawei Ascend G610 Replacement proximity brightness sensor: 4 단계, 이미지 1/2 Huawei Ascend G610 Replacement proximity brightness sensor: 4 단계, 이미지 2/2
    • With the help of a thin tool, pry up the side joints to remove the central body
  5. Huawei Ascend G610 Replacement proximity brightness sensor: 5 단계, 이미지 1/1
    • Unhook the display connector
  6. Huawei Ascend G610 Replacement proximity brightness sensor: 6 단계, 이미지 1/1
    • Unclip the touchscreen connector
  7. Huawei Ascend G610 Replacement proximity brightness sensor: 7 단계, 이미지 1/1
    • Unclip the brightness sensor connector
  8. Huawei Ascend G610 Replacement proximity brightness sensor: 8 단계, 이미지 1/1
    • Unhook the connector that connects the motherboard to the dock
  9. Huawei Ascend G610 Replacement proximity brightness sensor: 9 단계, 이미지 1/3 Huawei Ascend G610 Replacement proximity brightness sensor: 9 단계, 이미지 2/3 Huawei Ascend G610 Replacement proximity brightness sensor: 9 단계, 이미지 3/3
    • With the help of a thin tool, uncouple the mother board interlocked on the plastic hooks
  10. Huawei Ascend G610 Replacement proximity brightness sensor: 10 단계, 이미지 1/1
    • Remove motherboard
  11. Huawei Ascend G610 Replacement proximity brightness sensor: 11 단계, 이미지 1/1
    • With the help of a heat source of the tweezers remove proximity and brightness sensor by replacing it with a new one
결론
To reassemble the device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
it en
100%
irlanda님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Smilzo
회원 가입일: 2013년 11월 09일
10,335 평판
안내서 39개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 180
