소개
Replace the motherboard to give your phone a fresh start.
필요한 것
Pull and twist the pin near the bottom left-side of the phone to remove it from the headphone jack.
Firmly push down on the black plastic covering at the bottom of the phone, and pull down.
Remove the following screws securing the logic board to the main frame:
Five 2mm Phillips #000 screws
Two 2.5mm Phillips #000 screws
To replace the battery only the two orange 2.5mm screws need to be removed in this step.
Jarl Friis - 답글
Use the flat end of a spudger to gently snap open the first clip located on the the right arm of the retaining plate.
Use the flat end of a spudger to gently snap the second clip located on the left arm of the retaining plate.
Use the flat end of a spudger to gently lift the upper retaining plate from the phone.
Remove the two 2mm Phillips #000 screws securing the copper flex cable to the silver metal tab.
Use the pointy end of a spudger to wedge underneath the black circular vibrator motor near the bottom right of the phone.
Slowly lift up to separate the black circular vibrator motor from the adhesive.
다른 15명이 해당 안내서를 완성하였습니다.
댓글 6개
Hi, I need the mother board from where can I get it ??
Thanks Great post !!!
Amigo en que parte de la placa esta el wifi y bluetooth, gracias
Jean Jumbo - 답글
Friends in that part of the plate is wifi and bluetooth, thank you, have the problem that when I try to turn the wifi or bluetooth light does not help please
Jean Jumbo - 답글
My Huawei p6 suddenly doesn't unlock when I put in my PIN. Also no matter how many numbers I write when it asks me for the PIN, it never is enough. Would replacing the motherboard or any part of the phone help me unlock my phone? I don't know why all of a sudden this happened. I still get notifications while the phone is on and locked but can't enter the phone.
