주요 콘텐츠로 건너뛰기
Huawei Ascend W1 Rear Camera Lens Replacement
필요한 것
  1. Huawei Ascend W1 Rear Camera Lens Replacement, The phone's orientation.: 1 단계, 이미지 1/1
    • Flip the device over so that the back of the phone is facing you and the screen is against your palm.
  2. Huawei Ascend W1 Rear Camera Lens Replacement, Removing the back cover.: 2 단계, 이미지 1/1
    • Locate the slit at the bottom of the back cover.
    • Using your fingernail, lift up on the back cover to expose the battery.
  3. Huawei Ascend W1 Rear Camera Lens Replacement: 3 단계, 이미지 1/1
    • Lift the back cover off the phone.
    • The back cover is snapped onto the phone so you will feel it unsnapping as you remove it.
  4. Huawei Ascend W1 Rear Camera Lens Replacement, Removing the battery.: 4 단계, 이미지 1/3 Huawei Ascend W1 Rear Camera Lens Replacement, Removing the battery.: 4 단계, 이미지 2/3 Huawei Ascend W1 Rear Camera Lens Replacement, Removing the battery.: 4 단계, 이미지 3/3
    • Find the indented notch at the base of the battery.
    • Lift the battery out of the phone with your fingers by pressing forward and lifting upward.
  5. Huawei Ascend W1 Rear Camera Lens Replacement, Rear Camera Lens: 5 단계, 이미지 1/2 Huawei Ascend W1 Rear Camera Lens Replacement, Rear Camera Lens: 5 단계, 이미지 2/2
    • After removing the battery, remove the 2mm screws using a T5 Torx screwdriver.
    • There are eleven screws that hold the middle cover to the rest of the phone.
  6. Huawei Ascend W1 Rear Camera Lens Replacement: 6 단계, 이미지 1/2 Huawei Ascend W1 Rear Camera Lens Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to gently press against the back of the lens from the back of the frame.
    • Use tweezers to pry off the lens from the front of the frame.
결론
Tanner Cline
회원 가입일: 11/01/18
169 평판
안내서 2개 작성하였습니다
IUPUI, Team S3-G2, Harley Fall 2018 IUPUI, Team S3-G2, Harley Fall 2018 회원
IUPUI-HARLEY-F18S3G2
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 147
