주요 콘텐츠로 건너뛰기
Huawei Ascend XT Camera Replacement
필요한 것
  1. Huawei Ascend XT Camera Replacement, Camera: 1 단계, 이미지 1/2 Huawei Ascend XT Camera Replacement, Camera: 1 단계, 이미지 2/2
    • Use the 0.8 Sim driver bit to remove the SIM tray by inserting it into the hole on the side of the device.
    • Once the hole is pressed in firm, the SIM tray will pop out. This allows you to grab it and extract it from the device.
  2. Huawei Ascend XT Camera Replacement: 2 단계, 이미지 1/2 Huawei Ascend XT Camera Replacement: 2 단계, 이미지 2/2
    • Make a thumbs-up and use it to grip the plastic opening tool with the flat end pointing in the direction of your thumb.
    • Place the flat end of the opening tool slightly inside the charging port and place your thumb on the back of the phone.
    • Press into the phone with your thumb while pulling the opening tool back with your fist to begin prying the back off.
  3. Huawei Ascend XT Camera Replacement: 3 단계, 이미지 1/2 Huawei Ascend XT Camera Replacement: 3 단계, 이미지 2/2
    • Slide the flat end of the spudger along the edge of the device, prying off the back cover.
    • Carefully remove the back cover. This may be difficult due to glue on the inside.
  4. Huawei Ascend XT Camera Replacement: 4 단계, 이미지 1/2 Huawei Ascend XT Camera Replacement: 4 단계, 이미지 2/2
    • Use the Phillips head bit to remove 20 screws.
  5. Huawei Ascend XT Camera Replacement: 5 단계, 이미지 1/3 Huawei Ascend XT Camera Replacement: 5 단계, 이미지 2/3 Huawei Ascend XT Camera Replacement: 5 단계, 이미지 3/3
    • Carefully pull off the speaker assembly.
    • Carefully pull off the antenna assembly.
    • Carefully pull off the top left tab.
    • Carefully remove the back plate assembly.
  6. Huawei Ascend XT Camera Replacement: 6 단계, 이미지 1/2 Huawei Ascend XT Camera Replacement: 6 단계, 이미지 2/2
    • Carefully remove the camera wire tab from the mother board on the right side of the camera.
    • Remove the camera.
    • Replace the camera and rebuild.
결론
Jimmy Shields
회원 가입일: 09/24/18
577 평판
안내서 3개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 110
