이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the 0.8 Sim driver bit to remove the SIM tray by inserting it into the hole on the side of the device.
Once the hole is pressed in firm, the SIM tray will pop out. This allows you to grab it and extract it from the device.
Make a thumbs-up and use it to grip the plastic opening tool with the flat end pointing in the direction of your thumb.
Place the flat end of the opening tool slightly inside the charging port and place your thumb on the back of the phone.
Press into the phone with your thumb while pulling the opening tool back with your fist to begin prying the back off.
Slide the flat end of the spudger along the edge of the device, prying off the back cover.
Carefully remove the back cover. This may be difficult due to glue on the inside.
Carefully pull off the speaker assembly.
Carefully pull off the antenna assembly.
Carefully pull off the top left tab.
Carefully remove the back plate assembly.
Carefully disconnect battery ribbon wire from lower left corner of circuit board.
Use the spudger to pry lithium battery away from battery compartment.
Insert new battery and connect.
Carefully disconnect screen assembly ribbon wire from mother board.
Carefully remove the mother board from the screen assembly.
Replace screen assembly.
다른 한 분이 해당 안내서를 완성하였습니다.
