소개
This guide will detail how to remove and replace the battery of the Huawei Honor 6x. The battery needs to be replaced when it loses charge faster than expected, or when it is broken.
필요한 것
Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
Pry the screen off the back of the phone by pushing down on the opening tool.
Remove the four connectors by placing the spudger between the motherboard and the connectors.
Press upwards against the connectors until they disconnect.
Using the plastic card, remove the battery by lifting it from the casing.
다른 15명이 해당 안내서를 완성하였습니다.
댓글 3개
Where do i get its original battery, its mostly fake batteries out there in online stores
@satyanarayan+debbarma
I used this battery I found on Amazon. It wasn’t the original, by Huawei, but it’s the exact same thing. Works perfectly fine.
Thanks very much
