이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If your screen becomes cracked or is inoperable, the front display panel will need to be replaced. This process involves removing nearly every component of the phone before gaining access to the front display panel.
필요한 것
Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
Pry the screen off the back of the phone by pushing down on the opening tool.
Remove the four connectors by placing the spudger between the motherboard and the connectors.
Press upwards against the connectors until they disconnect.
이 단계에 사용된 도구:Plastic Cards$2.99
Using the plastic card, remove the battery by lifting it from the casing.
Remove the last two connectors from the motherboard using a spudger or your fingers.
다른 11명이 해당 안내서를 완성하였습니다.
