주요 콘텐츠로 건너뛰기
Huawei Honor 6x Rear Camera Replacement
필요한 것
  1. Huawei Honor 6x Rear Camera Replacement, SIM Card: 1 단계, 이미지 1/1
    • Turn off the device.
  2. Huawei Honor 6x Rear Camera Replacement: 2 단계, 이미지 1/2 Huawei Honor 6x Rear Camera Replacement: 2 단계, 이미지 2/2
    • Insert the SIM Card Eject Tool into the SIM card tray hole.
    • Press the eject tool into the hole until the tray clicks open.
  3. Huawei Honor 6x Rear Camera Replacement: 3 단계, 이미지 1/1
    • Remove the SIM tray from the device using two fingers.
    • When reinserting the SIM card, be sure it is properly aligned with the SIM tray.
  4. Huawei Honor 6x Rear Camera Replacement: 4 단계, 이미지 1/1
    • Remove the SIM card from the compartment using two fingers.
  5. Huawei Honor 6x Rear Camera Replacement, Back Cover: 5 단계, 이미지 1/2 Huawei Honor 6x Rear Camera Replacement, Back Cover: 5 단계, 이미지 2/2
    • Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
    • Pry the screen off the back of the phone by pushing down on the opening tool.
  6. Huawei Honor 6x Rear Camera Replacement: 6 단계, 이미지 1/3 Huawei Honor 6x Rear Camera Replacement: 6 단계, 이미지 2/3 Huawei Honor 6x Rear Camera Replacement: 6 단계, 이미지 3/3
    • Slide the opening tool or spudger along the bottom of the phone and around the edge.
  7. Huawei Honor 6x Rear Camera Replacement: 7 단계, 이미지 1/2 Huawei Honor 6x Rear Camera Replacement: 7 단계, 이미지 2/2
    • Once three sides of the screen are detached, pry the phone apart using two hands.
    • When separating the back panel from the screen, do not pull them too far apart. There is an interconnect that is attached to both sides that could break, or tear, if pulled too far.
  8. Huawei Honor 6x Rear Camera Replacement: 8 단계, 이미지 1/3 Huawei Honor 6x Rear Camera Replacement: 8 단계, 이미지 2/3 Huawei Honor 6x Rear Camera Replacement: 8 단계, 이미지 3/3
    • Remove the five 4mm Phillips #00 screws using a screwdriver.
  9. Huawei Honor 6x Rear Camera Replacement: 9 단계, 이미지 1/1
    • Remove the motherboard cover from the device using a spudger or your fingers.
  10. Huawei Honor 6x Rear Camera Replacement, Rear Camera: 10 단계, 이미지 1/3 Huawei Honor 6x Rear Camera Replacement, Rear Camera: 10 단계, 이미지 2/3 Huawei Honor 6x Rear Camera Replacement, Rear Camera: 10 단계, 이미지 3/3
    • Pry the two connectors off by wedging a spudger, or your finger, underneath the connector.
  11. Huawei Honor 6x Rear Camera Replacement: 11 단계, 이미지 1/1
    • Gently remove the camera assembly using a spudger or two fingers.
결론
다른 2명이 해당 안내서를 완성하였습니다.
M Morgan
회원 가입일: 10/08/18
653 평판
안내서 1개 작성함
Cal Poly, Team S13-G5, White Fall 2018 Cal Poly, Team S13-G5, White Fall 2018 회원
CPSU-WHITE-F18S13G5
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 15
전체 시간: 1,041
