주요 콘텐츠로 건너뛰기
Huawei Honor 8 LCD Screen Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
동영상 지침
결론
다른 6명이 해당 안내서를 완성하였습니다.
Witrigs
회원 가입일: 11/24/15
69,493 평판
안내서 378개 작성하였습니다
댓글 3개
Hi, Great job!
at 10 minites he start to put on some blue layer just to take it off again, why is that?
Is that the glue? If the blue is not the glue, what is holding the new display and the back of the phone on Place when we removed the glue at the begining?
Thanks / Ray
Raymond Sator - 답글
The blue plastic ist a protective foil on the double sided adhesive. You attach the adhesive to the surface, then you remove protective foil
Marius Gerdes -
This is the hardest screen replacement I have ever done. There is more adhesive than phone for the front and back glass. After leaving the heat gun on for 10 minutes the back glass still shattered when trying to get an exacto knife blade under it. The front glass repair here is not a good example of how it would go for a shattered screen. Really it would just shatter more.
Alex Month - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 6
전체 시간: 21,660
