주요 콘텐츠로 건너뛰기
Huawei Honor 8 Rear Glass & Frame Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Huawei Honor 8 Rear Glass & Frame Replacement, Rear Glass & Frame: 1 단계, 이미지 1/1
    • Make sure you spend at least 5 minutes heating up the adhesive. Prying off the glass cover too early can result in cracking the panel.
    • Using a heat gun or hairdryer, apply heat approximately three inches above the glass panel to warm up the adhesive around the outside edge of the phone.
    • Make sure to apply heat evenly across the outside edge of the device.
  2. Huawei Honor 8 Rear Glass & Frame Replacement: 2 단계, 이미지 1/2 Huawei Honor 8 Rear Glass & Frame Replacement: 2 단계, 이미지 2/2
    • Be careful not to tear the orange ribbon wire when removing the back panel.
    • Using a plastic opening tool, gently pry up a corner of the rear glass panel.
    • Slowly slide the plastic opening tool around the outside of the glass panel to break through the adhesive.
    • Additional plastic opening tools can be used to help separate the back panel from the phone body.
    • Gently lift the back panel off once all the adhesive has been removed.
  3. Huawei Honor 8 Rear Glass & Frame Replacement: 3 단계, 이미지 1/3 Huawei Honor 8 Rear Glass & Frame Replacement: 3 단계, 이미지 2/3 Huawei Honor 8 Rear Glass & Frame Replacement: 3 단계, 이미지 3/3
    • Using a Phillips PH00 screwdriver, remove the silver Phillips 3.5 mm screw circled in red.
    • Using a spudger, gently lift off the small metal tab that was held in place by the screw.
    • Gently pry off the orange ribbon wire on the back panel.
  4. Huawei Honor 8 Rear Glass & Frame Replacement: 4 단계, 이미지 1/1
    • Keep the tiny screws on a magnetic pad or a designated area so they will not be lost. There are eighteen screws in total.
    • Using a Phillips PH00 screwdriver, remove the eight silver Phillips 3.5 mm screws circled in red.
    • Using a Phillips PH00 screwdriver, remove the six black Phillips 4.0 mm screws circled in orange.
    • Using a Phillips PH00 screwdriver, remove the single silver 3.0 mm Phillips screw circled in yellow.
    • Using the Phillips PH00 screwdriver tip, gently scratch away the white stickers outlined in green circles to expose hidden screws.
    • Using a Phillips PH00 screwdriver, remove the two black Phillips 4.0 mm screws circled in green.
  5. Huawei Honor 8 Rear Glass & Frame Replacement: 5 단계, 이미지 1/3 Huawei Honor 8 Rear Glass & Frame Replacement: 5 단계, 이미지 2/3 Huawei Honor 8 Rear Glass & Frame Replacement: 5 단계, 이미지 3/3
    • Slowly slide the plastic opening tool around the perimeter of the inner lining.
    • Additional plastic opening tools can be used to help separate the inner lining from the phone body.
    • Gently pull the inner lining up to remove it from the phone body.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Jaret Wedow
회원 가입일: 09/25/17
1,752 평판
안내서 4개 작성하였습니다
Cal Poly, Team S18-G2, Forte Fall 2017 Cal Poly, Team S18-G2, Forte Fall 2017 회원
CPSU-FORTE-F17S18G2
4 회원들
안내서 24개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 5,071
