주요 콘텐츠로 건너뛰기
Huawei Honor 9 Screen Replacement
필요한 것
  1. Huawei Honor 9 Screen Replacement, Remove the Rear Glass: 1 단계, 이미지 1/1
    • Switch off your phone.
    • Heat an iOpener and apply it to the back of the phone for around two minutes. This will help soften the adhesive securing the rear glass.
    • You might need to reheat and reapply the iOpener several times during the rear glass removal.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Huawei Honor 9 Screen Replacement: 2 단계, 이미지 1/2 Huawei Honor 9 Screen Replacement: 2 단계, 이미지 2/2
    • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction cup to create a gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
  3. Huawei Honor 9 Screen Replacement: 3 단계, 이미지 1/3 Huawei Honor 9 Screen Replacement: 3 단계, 이미지 2/3 Huawei Honor 9 Screen Replacement: 3 단계, 이미지 3/3
    • Slide the opening pick to the bottom right corner.
    • Insert a second opening pick and slide it to the bottom left corner.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Huawei Honor 9 Screen Replacement: 4 단계, 이미지 1/3 Huawei Honor 9 Screen Replacement: 4 단계, 이미지 2/3 Huawei Honor 9 Screen Replacement: 4 단계, 이미지 3/3
    • Insert a third opening pick at the bottom left corner.
    • Start to slide the tip of the opening pick from the bottom left corner along the side of the Huawei Honor 9 to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Huawei Honor 9 Screen Replacement: 5 단계, 이미지 1/2 Huawei Honor 9 Screen Replacement: 5 단계, 이미지 2/2
    • If the adhesive gets hard to cut it is likely too cold. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Huawei Honor 9 Screen Replacement: 6 단계, 이미지 1/2 Huawei Honor 9 Screen Replacement: 6 단계, 이미지 2/2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
  7. Huawei Honor 9 Screen Replacement: 7 단계, 이미지 1/2 Huawei Honor 9 Screen Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    구매
    • Carefully lift the rear glass and remove it.
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
  8. Huawei Honor 9 Screen Replacement, Remove the Motherboard Shield: 8 단계, 이미지 1/1
    • Remove the three Phillips #00 screws (3.45 mm length).
    • Remove the five Phillips #00 screws (2.9 mm length).
  9. Huawei Honor 9 Screen Replacement: 9 단계, 이미지 1/2 Huawei Honor 9 Screen Replacement: 9 단계, 이미지 2/2
    • Carefully peel up the black thermal foil and remove it completely.
    • This foil is very thin and brittle and may rip easily.
    • Remove the Phillips #00 screw that is located underneath the thermal foil at the bottom center of the motherboard.
  10. Huawei Honor 9 Screen Replacement: 10 단계, 이미지 1/2 Huawei Honor 9 Screen Replacement: 10 단계, 이미지 2/2
    • Slide an opening pick under the right side of the motherboard shield.
    • Twist the opening pick sideways to release the clips that hold the shield in place.
    • Repeat the previous process and work your way around the motherboard shield until it pops out.
    There’s another screw to remove before you can lift the shield out. It’s hidden by the thermal foil and is at the bottom centre of the motherboard shield.
    Ryan Davies - 답글
    Hey Ryan,
    thanks for mentioning. That’s right and I added a bullet for this action.
    Dominik Schnabelrauch -
  11. Huawei Honor 9 Screen Replacement: 11 단계, 이미지 1/1
    • Remove the motherboard shield.
  12. Huawei Honor 9 Screen Replacement, Disconnect the Battery: 12 단계, 이미지 1/2 Huawei Honor 9 Screen Replacement, Disconnect the Battery: 12 단계, 이미지 2/2
    • Use a spudger to pry up and disconnect the battery flex cable.
  13. Huawei Honor 9 Screen Replacement, Remove the Battery: 13 단계, 이미지 1/3 Huawei Honor 9 Screen Replacement, Remove the Battery: 13 단계, 이미지 2/3 Huawei Honor 9 Screen Replacement, Remove the Battery: 13 단계, 이미지 3/3
    • Apply an iOpener to the center of the display, to loosen the adhesive beneath the battery.
    • The adhesive beneath the battery is very strong. You might need to repeat this process during the removal procedure several times. If heat does not work you can apply isopropyl alcohol (90+%) to the corners of the battery and let it penetrate the adhesive for several minutes before continuing.
    • The flex cables under the battery are laid out as seen in the image. Try to avoid prying in the marked areas to prevent damaging the cables.
    • Display flex cable
    • Interconnect flex cable
  14. Huawei Honor 9 Screen Replacement: 14 단계, 이미지 1/3 Huawei Honor 9 Screen Replacement: 14 단계, 이미지 2/3 Huawei Honor 9 Screen Replacement: 14 단계, 이미지 3/3
    • Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    • Insert the flat end of a spudger at the top right corner of the battery where the flex cable is located and start to pry the battery up.
    • Work your way down the right side of the battery and loosen the adhesive with the spudger.
  15. Huawei Honor 9 Screen Replacement: 15 단계, 이미지 1/3 Huawei Honor 9 Screen Replacement: 15 단계, 이미지 2/3 Huawei Honor 9 Screen Replacement: 15 단계, 이미지 3/3
    • Insert the flat end of a spudger at the top left corner of the battery and pry the battery up.
  16. Huawei Honor 9 Screen Replacement: 16 단계, 이미지 1/3 Huawei Honor 9 Screen Replacement: 16 단계, 이미지 2/3 Huawei Honor 9 Screen Replacement: 16 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • The display and interconnect flex cables are running underneath the battery. Don't damage them while cutting the remaining adhesive.
    • Insert an opening pick or plastic card between the frame and the battery.
    • Cut any remaining adhesive underneath the battery.
    • Pry up the battery until you can get a good grip.
  17. Huawei Honor 9 Screen Replacement: 17 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    구매
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • Remove any remaining adhesive from the phone and clean the glued areas with isopropyl alcohol and a lint-free cloth before installing the new battery.
    • If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
    Hallo!Ich habe die Akku gekauft und alle so wie hier steht gemacht.Nichts beschädigt. Nach einschaltung meine Display funktioniert, aber nicht empfinden.Ich kann nicht meine Android Pin code geben,keine Reboot machen und kann ich die Hisuite auch nicht verbinden(braucht Code)….Was meinen Sie,was ist die Problem?Momentan kann Mann nicht im Service bringen….
    Frau ungarische - 답글
  18. Huawei Honor 9 Screen Replacement, Remove the Screen: 18 단계, 이미지 1/2 Huawei Honor 9 Screen Replacement, Remove the Screen: 18 단계, 이미지 2/2
    • Use a spudger to pry up and disconnect the display flex cable.
  19. Huawei Honor 9 Screen Replacement: 19 단계, 이미지 1/2 Huawei Honor 9 Screen Replacement: 19 단계, 이미지 2/2
    • Use a pair of tweezers to peel the display flex cable off the frame.
  20. Huawei Honor 9 Screen Replacement: 20 단계, 이미지 1/1
    • Remove the four Phillips #00 screws (3.2 mm length).
    • Remove the three Phillips #00 screws (2.9 mm length).
  21. Huawei Honor 9 Screen Replacement: 21 단계, 이미지 1/1
    • Apply an iOpener to the bottom end of the display to soften the adhesive beneath the loudspeaker.
  22. Huawei Honor 9 Screen Replacement: 22 단계, 이미지 1/3 Huawei Honor 9 Screen Replacement: 22 단계, 이미지 2/3 Huawei Honor 9 Screen Replacement: 22 단계, 이미지 3/3
    • Slide an opening pick under the loudspeaker and daughterboard cover.
    • Slide the opening pick to the right end of the cover and twist it sideways to lift the loudspeaker out of its recess.
  23. Huawei Honor 9 Screen Replacement: 23 단계, 이미지 1/1
    • Remove the loudspeaker.
  24. Huawei Honor 9 Screen Replacement: 24 단계, 이미지 1/2 Huawei Honor 9 Screen Replacement: 24 단계, 이미지 2/2
    • Use a spudger to pry up and disconnect the home button flex cable located at the bottom right of the phone.
  25. Huawei Honor 9 Screen Replacement: 25 단계, 이미지 1/1
    • Apply a heated iOpener to the display for around two minutes to soften the adhesive underneath.
    • You might need to reheat and reapply the iOpener several times during the removal procedure to get the adhesive warm enough to cut. Follow the iOpener instructions to avoid overheating.
  26. Huawei Honor 9 Screen Replacement: 26 단계, 이미지 1/3 Huawei Honor 9 Screen Replacement: 26 단계, 이미지 2/3 Huawei Honor 9 Screen Replacement: 26 단계, 이미지 3/3
    • Once the screen is warm to the touch, apply a suction cup near the top edge of the phone right under the earpiece speaker.
    • If the phone's screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Pull up on the suction cup and insert the tip of an opening pick under the display near the earpiece speaker.
    • Slide the opening pick to the top left corner of the phone to cut the adhesive.
  27. Huawei Honor 9 Screen Replacement: 27 단계, 이미지 1/2 Huawei Honor 9 Screen Replacement: 27 단계, 이미지 2/2
    • Insert a second opening pick and slide it to the top right corner of the phone.
  28. Huawei Honor 9 Screen Replacement: 28 단계, 이미지 1/3 Huawei Honor 9 Screen Replacement: 28 단계, 이미지 2/3 Huawei Honor 9 Screen Replacement: 28 단계, 이미지 3/3
    • Insert a third opening pick at the top right corner of the screen.
    • Slide the opening pick from the top right corner down the right edge of the phone and cut the adhesive with it.
    • While cutting, make sure the pick slides under the display panel and not just between the display and the front glass.
  29. Huawei Honor 9 Screen Replacement: 29 단계, 이미지 1/2 Huawei Honor 9 Screen Replacement: 29 단계, 이미지 2/2
    • If cutting becomes too difficult, reheat and reapply the iOpener to the screen.
    • Insert a fourth opening pick at the bottom right corner of the screen.
    • Slide the tip of the opening pick along the bottom edge of the screen to cut the adhesive.
  30. Huawei Honor 9 Screen Replacement: 30 단계, 이미지 1/2 Huawei Honor 9 Screen Replacement: 30 단계, 이미지 2/2
    • Insert a fifth opening pick at the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the phone to cut the remaining adhesive.
    • Do not remove the display all the way yet. The home button and display flex cables are still threaded through the midframe.
  31. Huawei Honor 9 Screen Replacement: 31 단계, 이미지 1/2 Huawei Honor 9 Screen Replacement: 31 단계, 이미지 2/2
    • Make sure the display flex cable does not stick to the frame and carefully thread it through the gap at the bottom of the frame.
  32. Huawei Honor 9 Screen Replacement: 32 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    구매
    • Remove the screen.
    • Remove any remaining adhesive from the midframe, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • The best way to secure the new screen is with a sheet of custom-cut double-sided tape, but high bond double-sided tape will also work. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen with the frame and press it into place.
결론
다른 4명이 해당 안내서를 완성하였습니다.
회원 가입일: 11/23/16
202,516 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,718개 작성하였습니다
댓글 한 개
Is this screen will fit on honor 9x?
Seraj Almarzouq - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 16
30일 전: 79
전체 시간: 14,661
