주요 콘텐츠로 건너뛰기
Huawei Ideos S7 Slim Logic Board Replacement
필요한 것
  1. Huawei Ideos S7 Slim Logic Board Replacement, Battery: 1 단계, 이미지 3개 중 1개 Huawei Ideos S7 Slim Logic Board Replacement, Battery: 1 단계, 이미지 3개 중 2개 Huawei Ideos S7 Slim Logic Board Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Place the tablet on a flat clear surface to keep the screen safe.
    • Slide the larger portion of the back cover off the tablet.
    • This will reveal the battery.
  2. Huawei Ideos S7 Slim Logic Board Replacement: 2 단계, 이미지 2개 중 1개 Huawei Ideos S7 Slim Logic Board Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the battery out with your finger.
    • Make sure you use the slot near the bottom of the device as shown. Trying to lift from anywhere else will not work and may damage the battery or the device.
  3. Huawei Ideos S7 Slim Logic Board Replacement, Logic Board: 3 단계, 이미지 2개 중 1개 Huawei Ideos S7 Slim Logic Board Replacement, Logic Board: 3 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, pry off the top cover casing gently by moving the tool along all three sides.
  4. Huawei Ideos S7 Slim Logic Board Replacement: 4 단계, 이미지 1개 중 1개
    • With a T5 hexagonal head, remove the nine black 2.5 mm torx screws. Place them carefully aside on the magnetic mat.
  5. Huawei Ideos S7 Slim Logic Board Replacement: 5 단계, 이미지 3개 중 1개 Huawei Ideos S7 Slim Logic Board Replacement: 5 단계, 이미지 3개 중 2개 Huawei Ideos S7 Slim Logic Board Replacement: 5 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, pry off the back casing gently on each side of the tablet.
  6. Huawei Ideos S7 Slim Logic Board Replacement: 6 단계, 이미지 3개 중 1개 Huawei Ideos S7 Slim Logic Board Replacement: 6 단계, 이미지 3개 중 2개 Huawei Ideos S7 Slim Logic Board Replacement: 6 단계, 이미지 3개 중 3개
    • Using a Phillips #00 screwdriver, remove the following screws:
    • Four 5mm wide grey Phillips screws on the logic board.
    • One of the 5mm screws is hidden under the circular white tape in the center of the logic board.
    • Seven 3mm small grey Phillips screws (four on one side, three on the other) from the black side casing.
  7. Huawei Ideos S7 Slim Logic Board Replacement: 7 단계, 이미지 3개 중 1개 Huawei Ideos S7 Slim Logic Board Replacement: 7 단계, 이미지 3개 중 2개 Huawei Ideos S7 Slim Logic Board Replacement: 7 단계, 이미지 3개 중 3개
    • Disconnect the five cables connected to the logic board and then carefully lift the logic board out of the casing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Gregory Philip
회원 가입일: 09/21/16
585 평판
안내서 4개를 작성함
UC Davis, Team 1-1, Oliver Fall 2016 UC Davis, Team 1-1, Oliver Fall 2016 회원
UCD-OLIVER-F16S1G1
5 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 681
