주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide show the process of back panel replacement on the Huawei M750.
부품
지정된 부품이 없습니다.
  1. Depress the top of the battery cover, and pull downwards towards the base of the phone.
    • Depress the top of the battery cover, and pull downwards towards the base of the phone.
  2. Remove the battery by levering the battery out, using the cut just below the camera.
    • Remove the battery by levering the battery out, using the cut just below the camera.
  3. Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
  4. Using the T5 Torx screwdriver, remove the six 6mm screws. Using the T5 Torx screwdriver, remove the six 6mm screws.
    • Using the T5 Torx screwdriver, remove the six 6mm screws.
  5. Using the opening tool, pry the back panel from the front panel. Work your way around the phone until the panels separate evenly.
    • Using the opening tool, pry the back panel from the front panel.
    • Work your way around the phone until the panels separate evenly.
    • This step may require a substantial amount of leverage.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kshitiz Thapa
회원 가입일: 2018년 02월 11일
389 평판
안내서 3개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 143
